places where coolant could leak into engine?
#31
I found mine was on backwards too. My Degas side (white trim) was on the opposite side. The radiator (rad) was o.k.
I would think if it didn't matter they wouldn't have marked them. I noticed my fluid level was up to cold mark when cold and high in the degas bottle when hot lately. After I reversed the mistake I noticed the fluid is now down to the Venturi tee line.
If it's low in the morn I will add until at the cold min line.
#33
Venturi Tee
Your correct John, The coolant runs from the vertical EGR cooler back to the degass bottle. as it flows through the venturi tee, it pulls vacuum from the radiator side this vacuum will prevent air pockets in the radiator which was what caused them to fail. Incorrect Tee installation can cause radiator failures.
#34
#35
Update upper radiator hose
Do you think, or have you seen, where incorrect tee installation would cause the hoses to leak?
I had my radiator replaced under the TSB. They did the venturi tee at the same time, but put it on backwards. I've since developed a leaky upper hose or thermostat housing o-ring.
The venturi tee will not cause the leak. You leak is a normal concern I have come across. The orignal upper rad hose was a single oring. Ford has a updated hose that has a white end on the thermostat side. This redesigned hose now has a double oring. Most of the time, the hose may not be covered by warranty. But it they do remove it and see rubbing makes on the housing, the housing would be covered and hose should be updated then and covered as casual failure to the housing.
The orignal hose
The updated hose
#36
Is there a TSB or something for the hose replacement? If not how would it cost me to have the dealer fix it?
I have an early 08 truck. Maybe they'll cover it?
I have to check again, but I do not remember the white looking hose end. Is this something I can do myself or is there a special tool for the clips that hold the hose on?
#37
#38
#39
DPF is an emissions device so that should be covered separately. I think that is 60K for emissions stuff.
#40
Warranty coverage
kdaug5
19
01-06-2017 06:47 PM
rjdavis21
20
07-28-2009 08:40 AM
