7.5L Ford 460 Oil Cooler Heat Exchanger Failure
Old 05-10-2016, 07:03 AM
cbakker's Avatar
cbakker
cbakker is offline
Thanks for clearing that up. You must have read through the whole thread. I think your solution is perfect and I have no idea why I wouldn't go that route. How many gallons of oil are you running anyway?
  #227
Old 05-10-2016, 09:40 AM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Originally Posted by ranch-verteran
if you tow, go on long distance drives, haul with this, or daily commutes involve grades then the more you cool the oil the less oil changes, the less oil filters you will need and the less overall maintenance and longevity you will get out of this engine. i have a 18" by 30" and noticed significant drop, but still to hot of oil going back to engine. so next step is to go bigger.
i like the 460 contrary to most but not stock. i currently have 4 or 5 pickups with these engines and a spare on hand in case. i work and max these engine out, but they keep on giving with little to no maintenance. except for the typically spark plug that fails when ever engine gets hot. i have lost 2 on 1 side and 1 on the other going up hill, but even on 3 dead cylinders it still climb pulling 4 tons.
i got a pickup that's getting a 460 swapped out for maintenance, but in the process putting in a efi controller and a 7.3 idi radiator as they will fit ironically. 4x the cooling capacity and putting a 4x4 oil cooler, seeing what kind of mileage i squeeze out, so far at 15, but should be closer to 20 when done. and that's towing mid size loads. controlling the a controller for these engines, which runs $1500 Canadian, $900 us. it basically is a plug and play, so more uniform injections and the ability to custom tune much like a modern vehicle can be. but without environmental restrictions. i can put on over 10k miles a month so i get what i can out of fuel.
Since you hijacked this already, I will ask my question, what type of EFI controller are you going with? I will have to look into the 7.3L idi radiator myself.
  #228
Old 05-10-2016, 10:01 AM
ranch-verteran's Avatar
ranch-verteran
ranch-verteran is offline
theres only 1 option for these engines available and its a company out of Canada. i will get contact info.
i haven't tried a 7.3 radiator in a 460 but going to switch all to them. a good radiator stock size for a 460 4 core is $300. the 6.9/7.3 is $600. being they keep a 7.3 engine around 130 degrees so there fairly efficient. i run a 4 core currently in 460's and it helps keep cool but needs more. the difference between the 2 radiators is that the 6.9 and 7.3 has 2 sizes, stock and tall. the tall is the one i have in my 7.3 ford. the stock is the same thing i have in 460. the other is the way the fins and tubes are positioned. which is why overall the 6.9/7.3 radiator is a better design. there are stock houses for the 7.3 and 460 that can make connections. as far as core support goes, its either cut out and weld or go to a salvage and get a 7.3 or 6.9 81 thru 92. the bolt pattern for body didn't change much from 81 to 96 just shape of fenders. 8 mill and 10 mill sockets both most common.
cbbakker,
i am at 7 quarts of oil. but only get 5 to 6 out on a oil change. unless on a hill. with larger size going to be near 8 to 9 quarts. and the way i have everything set, its pre primed when engine starts which is nice.
  #229
Old 05-10-2016, 10:21 AM
cbakker's Avatar
cbakker
cbakker is offline
How did you accomplish that?
<OS_xpc_uuid: <uuid: 0x14eb6b70> 90A06362-391A-4151-A83E-BB2653B3EF5A>
  #230
Old 05-10-2016, 10:43 AM
ranch-verteran
[QUOTE=cbakker;16273923]How did you accomplish that?
OK so post didn't post, editing.
by accident, between 3/4 oil lines and oil cooler.
the oil filter sits under coolant tank. the hose from engine is 2ft roughly. the oil drains back in this. but ahead in the cooler and return lines theres about a quart and a half. also any oil that cant drain thru engine, cant drain back because of the setup i have so theres a minor amount trapped already. when i go to start, i see a immediate jump in pressure 10 to 20 psi on 1st crank average. where as before there was a minor delay of to up to 3 seconds. i also am running a high flow oil pump. its minor, but will make a difference long term.
Last edited by ranch-verteran; 05-10-2016 at 10:49 AM. Reason: nothing came up when posted, blank
  #231
Old 05-10-2016, 11:11 AM
85lebaront2
Ok, I just wondered because as you can see in my signature, I have mine running using an EEC-V box reflashed to run my non-catalyst truck.
  #232
Old 05-11-2016, 10:42 AM
cbakker's Avatar
cbakker
cbakker is offline
Back to the oil cooler talk.
I ended up ordering the Derale 15451 kit, because the CXRacing kit only came with the M20 filter adapter. It is pretty similar to some of the setups used by other guys in this thread. I'm not crazy about the 1/2" pipe thread ports, or the barbed hose fittings. I plan on giving them a try, and switching to hydraulic hose with AN fittings, when time allows.
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
For $108 shipped and ~$10 for the block to filter adapter, I can afford to spend more on good hoses and wasting time to figure out mounting brackets for the cooler.
  #233
Old 05-13-2016, 06:56 PM
cbakker's Avatar
cbakker
cbakker is offline
Can anyone tell me why the lower hose for a 460 doesn't work? We're the old water pumps bigger? I ordered the 351 hose from napa and both ends are 1.75" ID.
  #234
Old 05-16-2016, 10:32 PM
Rami Navarrete's Avatar
Rami Navarrete
Rami Navarrete is offline
I Cant See The Pictures!! It would help a lot
  #235
Old 05-18-2016, 08:58 PM
85lebaront2
Yes, the older pumps dated clear back to 1968 when the 385 engines came out. The older radiators had a 2" lower hose fitting. When Ford decided to stuff the 460 in the "new" body/chassis in 1983, they were constrained by the existing platform and the 351M/400 used a 1.75" lower hose. When the EFI 460 came out, for the first 2 + years they used an air to oil cooler, 1990 it was changed to a water to oil cooler and apparently due to the short kinked hose from the cooler to the water pump, it was easier to make all the fittings 1.75".
If you buy a NBH 902 hose reducer from NAPA, it will take the 1.75" water pump inlet nipple up to 2" allowing the 1983-early 1990 hose to be used.
  #236
Old 05-18-2016, 11:01 PM
cbakker's Avatar
cbakker
cbakker is offline
I picked up the '90 351 hose from napa a few days ago but I haven't got to trying it out yet.
  #237
Old 07-30-2016, 10:35 PM
pat67shorty's Avatar
pat67shorty
pat67shorty is offline
I deleted my oil cooler today. The Motorcraft KM-1662 lower hose worked perfectly for me. My truck has the original water pump and it has a larger neck than the reman pump I have on the shelf. The original pump neck is 1.96" and the ID of the motorcraft hose at the water pump end is 1.89". The reman water pump neck is 1.753". I tried the 351 hose first and it would have to stretch a bit to fit my pump, but would work with the reman pump. I used the Ford racing 90* adapter and an e-bay BBF/C/M filter nipple.
First pic is the factory oil cooler vs the adapter off of an 80's truck. Both share the same bolt threads, if you wanted to go that way. However, the bolt on the 80's unit uses a NLA gasket, instead of an o-ring like the factory cooler.
The following users liked this post:
  #238
Old 07-31-2016, 07:30 AM
85lebaront2
Nicely done! I am very familiar with that NLA gasket, one of it's issues is tending to loosen on it's own as the weight of the filter wants to turn the assembly counter-clockwise. Apparently, either your truck is an early water to oil system, or the pump was changed previously. Interestingly enough, many aftermarket sources list the early pump through 1991.
  #239
Old 07-31-2016, 10:12 AM
pat67shorty
It looks like the later "oil cooler" style water pump. The snout just isn't machined down as far as the F5TE reman pump I have on the shelf.
  #240
Old 07-31-2016, 10:52 AM
85lebaront2
Ok, I used a NAPA NBH902 huse bushing to allow a 1983-early 1990 lower hose to fit on the later (1994-97) pump on my new engine. See this section: https://www.ford-trucks.com/forums/1...l#post16205735
Quick Reply: 7.5L Ford 460 Oil Cooler Heat Exchanger Failure
