bogging while accelerating- 94 f150 4.9L - Ford Truck Enthusiasts Forums
Old 11-12-2009, 07:47 PM
gotford? gotford? is offline
gotford? is starting off with a positive reputation.
Question bogging while accelerating- 94 f150 4.9L
my truck is bogging down in all gears(manual), it only bogs down when i try to put it under heavy acceleration. ive replaced the plugs, wires, cap,rotor,and fuel filter...still no improvement.what could this be? injectors? coil?sensor? i just need some answers as to what it may be and how i can fix it. im not to good with mechanics so please bear with me.
Old 11-12-2009, 08:28 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Sounds like a failing fuel pump. Does it do it on both tanks? The only way to correctly diagnose it is to put a fuel pressure gauge on it and see what the pump is doing.
Old 11-13-2009, 12:52 AM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Pull the codes for starters before engaging in shotgun therapy and incurring unnecessary expense.
Old 11-13-2009, 02:13 AM
i would pull the codes but i dont know how and dont have any of the neccesary tools(i think) could you explain how to do this? and i appreciate the replies.
Old 11-13-2009, 03:02 AM
jem44357's Avatar
jem44357 jem44357 is offline
jem44357 is starting off with a positive reputation.
I recently replaced the coil on my 140000.00 mi 93 4.9. It would fall flat on its face (so bad you could not hear it running) when I would put it to the floor, any gear any speed or just sitting idling. If I held it long enough it would stall. If I got out of it in enough time it would run almost normal ( slight roughness). I could not find the source, switched tanks, replaced the fuel filter, popped the cap/rotor/wires and pulled the plugs and cleaned everything... no change. Just so happened that as I passed by the engine bay while it was running in the garage I heard it "snap" a few times than I knew it was spark leaking out. I could never "see" the spark but could hear it. Decided it must be the back side of the coil. Removed the coil and the plastic protector was bulged out from rust. $18.00 at Murry's and it runs like a brand new truck with 140000.00 miles on it.
BTW I never got a check engine light and I never bothered to pull the codes. The day I bought the reader was the day I heard the "snap".
Try this for the codes I think it is what you need... http://www.ford-trucks.com/forums/11...an-eec-iv.html
I found it by starting to type "how to pull..." in the search drop down menu for the forums.
Jim
Old 11-14-2009, 01:45 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Quote:
You can go to Autozone and they will pull your codes for free and tell you what the codes mean (a print out) for your vehicle.
Definitely the best way to go is to pull the codes instead of guessing.
Old 11-14-2009, 04:49 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Code readers are handy, but all they do is tell you what circuit needs attention. You still need to trouble shoot the circuit to find the actual problem. You can test the sensors with a meter if you find the proper readings for them. I bought an AutoXray, monitor, freeze frame, the whole works, about 4 years ago for $400 so it's not a $29 cheapo and I keep it updated. Still the most use I get out of it is turning off the check engine light for people. The analyzers mechanics use cost in the thousands to be capable of telling you exactly what part to replace and they're still not always right.
Old 11-19-2009, 03:10 PM
Wynn96 Wynn96 is offline
Wynn96 is starting off with a positive reputation.
I also think it sounds like a bad fuel pump. When mine went, it would fall on its face when I floored it. Other symptoms were a hard shudder when starting. Usually it would not fire the first time I cranked it. I put in a Napa replacement pump for about $140, and haven't had a problem since.
Old 11-19-2009, 06:51 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
assuming that the ignition, cats, etc and everything else are ok...a known remedy solver for part throttle/hesitation/bog is to install a restrictor plate reducing the holes to 3/8" inbetween the EGR & manifold.
Old 11-20-2009, 06:50 PM
BigBlue88 BigBlue88 is offline
BigBlue88 is starting off with a positive reputation.
+1 Harte3
On a 94, you can pull your computer codes with 5 minutes and a paper clip, and it'll blink out "morse code" with the check engine light (or you can use a continuity tester/multimeter and count beeps/needle sweeps). Check the following links:
Ford Ranger/Bronco II EEC-IV Testing
Ford Fuel Injection How To Run a Self-Test
Then look them up on the same sites, either 2 digit or 3 digit codes. It's daunting at first, but after one or two tries, it's boring simple. It'll give you a GREAT head-start on what to look at, and all you have to do is steal a paperclip from work.
Bogging under load will be either EGR (too much), like folks have said before, or a lean condition, probably caused by a bad O2 sensor (or a bad EGR, if it's not allowing any exhaust at all).
My 88 had both problems, got great MPG and had no power. It threw one code for "rich all the time" and another for "EGR valve not moving". "Rich all the time" caused it to run the engine lean, and the EGR valve really wasn't moving, so it was getting even more oxygen than normal under cruise because it wasn't being displaced by exhaust. Ford changed the EGR control system frequently, but on my 88, the vacuum solenoids were impossible to find.
Old 11-25-2009, 05:06 PM
it was bad spark plugs...bought em from kragen, cant even get my money back. turned out to be the simplest thing
Old 11-25-2009, 09:17 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
My truck's been bogging down too. Automatic. I'm going to eye this thread.
D/A sander bogs down under load Pitweiller13 Paint & Bodywork 3 01-11-2016 02:55 PM
Bogs down when giving gas!!! lumberjack_964 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-03-2013 09:30 AM
7.3L 2000 F250 bogs down at mid-point of acceleration accompanied by some shaking. rdbesq 1999 - 2003 7.3L Power Stroke Diesel 5 06-21-2013 11:00 PM
bogs down in gear Neauxx 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-14-2012 07:45 PM
1989 150 i6 Starts fine bogs down on acceleration ben's1989150 1987 - 1996 F150 & Larger F-Series Trucks 1 02-03-2012 02:36 AM
Tags
1988, 49, 49l, 94, acceleration, bronco, coil, egr, f150, ford, freeze, hard, install, plug, start, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
