Torqueshift flush machine
11-11-2009, 11:44 PM
on
Does the transmission flushing machine actually heat the fluid during a flush or depend on the transmission to provide the heat?
JimB
11-12-2009, 07:11 AM
on
The machine provides the heat. Be aware that some dealerships have a flush machine but not all are heated flush machines. Make sure you ask which they use.
11-12-2009, 07:19 AM
you must use the heated one so that the torque converter gets flushed as well. I has a thermostat in it.
11-12-2009, 11:42 AM
on
I thought the thermostat was in the lines going to the transmission cooler.
11-12-2009, 11:59 AM
11-12-2009, 09:19 PM
There is only one thermostat. It's inside the transmission, in the pump body. There is no thermostat in the torque converter.
11-14-2009, 06:42 AM
Quote:
Originally Posted by
Mark Kovalsky
Thanks for the correction Mark! I knew there was one in there somewhere
CollinsCD
Maryland Chapter
08-06-2014 06:18 AM
Frankenbiker
Texas Chapter
05-31-2012 06:32 PM
Tom
1999 to 2016 Super Duty
65
03-25-2010 05:05 PM
whalerron
11-15-2007 07:09 AM
converter ,
f150 ,
f250 ,
flush ,
flushing ,
ford ,
heated ,
machine ,
maintenance ,
schedule ,
shift ,
torque ,
torqueshift ,
transmission ,
troque
