Door jamb switch help - Ford Truck Enthusiasts Forums
Old 11-11-2009, 04:06 PM
Crew_Cab_78's Avatar
Crew_Cab_78 Crew_Cab_78 is offline
Crew_Cab_78 is starting off with a positive reputation.
I ordered some door jamb switch's to replace my crushed one's on the front door's the other day. They are the one's that screw into the jamb. They look correct and have the right plugs for the electrical connections but looked a little long. They where the only one's listed for the 73-79 trucks so I ordered them up from NPD. I screwed them in the other day when I had a free minute, but they contact the door far before it's closed. Are they adjustable? Haven't had time to mess with it again yet but just wanted to see if anyone else had run into this problem.
Thanks
Old 11-11-2009, 05:14 PM
F250army45d F250army45d is offline
F250army45d is starting off with a positive reputation.
should just screw in and then stick out maybe 3/8 or 1/4 and need no adjusting but I could be wrong.
Old 11-11-2009, 05:29 PM
shadowviper12345 shadowviper12345 is offline
shadowviper12345 is new and has a neutral reputation at this point.
as long as the door can shut and the switch functions what does it matter?
Old 11-11-2009, 06:04 PM
That's the thing the door Doesn't Close. It makes contact and not even close to latching.
Old 11-11-2009, 07:09 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Some jamb switches are extended until you close the door and they have a "memory" to keep them adjusted in.
Not sure what is going on then. If the adjuster is screwed in all the way and "plunger" is hanging up, maybe they are broken.
Josh
Old 11-11-2009, 08:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Mine looked too long too. I screwed them in and when I shut the door the body pushed down into the hex "barrel" and everything worked fine.
Old 11-11-2009, 09:44 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Quote:
Winner. The center shaft will slide in once the door is completely closed.
Old 11-11-2009, 10:17 PM
Looked at it again tonight and found out that it does slide through the hex. Another mystery solved, Thanks for the answers.
Old 11-11-2009, 11:36 PM
pidaster pidaster is offline
pidaster is starting off with a positive reputation.
Just put it in and close the door. It will slide down the the spot it needs to stay at.
Reproduction door jamb VIN decals Super Mech 1987 - 1996 F150 & Larger F-Series Trucks 16 11-26-2013 06:57 PM
Square Holes in Door Jamb rbaruffi 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-03-2011 11:39 AM
Dome light short - '75 F-250 Paul49 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-29-2011 11:45 AM
Did early Dentsides come with Vin sticker on drivers door jamb? fitzmotor 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-29-2011 10:25 PM
door jamb switches for dome light 1978f-250 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-24-2009 11:57 AM
Tags
1997, 2003, 3way, 78, adjust, door, f100, f150, ford, jamb, light, ranger, replace, replacing, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
