truck rpms
Old 11-11-2009, 02:54 PM
andyman91's Avatar
andyman91
andyman91 is offline
truck rpms
I got my truck about a week ago not running and got it running today and at idle the rpms run around 2000 i was wondering if the problem could be with the fuel pump.
Old 11-11-2009, 03:35 PM
brett12396f150's Avatar
brett12396f150
brett12396f150 is offline
I dont think a fuel pump can cause high rpms :P
Old 11-11-2009, 03:42 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Vacuum leak(s)! The plastic vacuum hoses are a well-known source of leaks due to their aging and tendency to develop cracks. Rusted through metal vacuum reservoirs are also high on the list. Stuck idle control valve is next on the list AFTER every vacuum circuit has been checked and repaired.
Old 11-11-2009, 03:43 PM
Virto's Avatar
Virto
Virto is offline
Suspect the IAC or a bound throttle cable. The fast idle at start should peak at about 1500 and then quickly fall off. You can kick it down manually with a tap of the accelerator.
Maybe a really massive vacuum leak? I'd pull codes if I were you. fordfuelinjection.com
Old 11-12-2009, 04:27 PM
andyman91's Avatar
andyman91
could it be the tranny that has been causing problems lately think i fixed it but was wondering.
Old 11-15-2009, 09:10 AM
rla2005's Avatar
rla2005
rla2005 is offline
Not very likely.
Old 11-15-2009, 09:43 AM
vancouver island's Avatar
vancouver island
vancouver island is offline
my truck was doing same at idle cleaned the IAC what a difference know on to surging problems. I also replaced all vacuum lines with rubber hose made a huge difference
Farmboypowerstroke
12-12-2013 11:52 AM
chadstar
2004 - 2008 F150
09-25-2006 09:14 PM
Renegade361
13
05-26-2006 01:39 PM
Kerr
04-17-2006 11:54 AM
littlerayj
11-04-2004 03:47 PM
Quick Reply: truck rpms
