Are superduty supposed to go at 90 mph with overload stuff SAFETY? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-10-2009, 11:52 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
Well I was on I94 so lot people go over 80 mph.
It get my attention. It was company truck with welder stuff. It cruise at 90 mph it not drive straight it like wander due 50 mph wind. I think it 00 or 01 f250 XL.
How they think it safe. Our 01 F250 crew cab aren't safe over 85 mph or you feel shake from wind hit front end and mpg from 11 drop to 5-6 mpg at that speed.
I wish I have got pictures of roof company's 99-01 2 f250 which really really bad shaped it look like it came from Mexican or construction. It worst than that picture. bed are about 9" low on right side than Left side. It ever cruise at 85 mph. No DOT or police stop it. It have 5 ladders on rack and full of roof material in bed.
Old 11-11-2009, 12:12 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
wow dude I only understood half of what you typed... no offense.
my 06 goes 98 mph with no shakes or shimmys. even with 35's.
Old 11-11-2009, 12:39 AM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
The OP's signature says, "Sorry for my bad grammar." He already knows.
Milwaukee1979F150, out of curiosity where are you from and what is your first language?
Old 11-11-2009, 12:58 AM
Michigan in Trenton.
ASL= American Sign Language.
Robs06SuperDuty
how you could get to 98 mph? Our F250 just stop 90 mph but will go pass if you lift gas pedal off then push again it go 95 then drop to 90 mph.
Old 11-11-2009, 02:30 AM
Quote:
Originally Posted by Milwaukee1979F150 View Post
Robs06SuperDuty
keep your foot on the skinny... Mine limits out a 98, just stays there, no rev limiter or anything. It just holds there until you let off the gas. and thats stock programming. I dont have a tuner.
what year is yours?
Old 11-11-2009, 02:44 AM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.1 is gaining momentum as a positive member of FTE.
My 03 excursion V10 will go right up to the 96MPH limiter and its, very, steady and goes straight. Like a train on rails, no problems at all.
Old 11-11-2009, 06:24 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Yes a superduty will get up and run with the best of them. Does that mean you should be doing it? Probably not since you yourself said the trucks are showing the wear pretty bad.
So control your speed so you go home at nite...or convince the company that they need to do some maintance. Truck should be stable at all speeds.
Old 11-11-2009, 06:37 AM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
I can recall on the Trans-Canada Hi-Way,,,coming home from Nova-Scotia,,with my 04' F-350 V-10, 6-speed 4:30's pulling my 16' Enclosed Pace American trailer,,,,looking down at the speedo,,,,,opps,,hey boys look,,,90 mph,,,, I backed it down then,,,,the truck was still pulling too!!
Funny,,,that truck went to Nova-Scotia,,,twice,,,Got traded in with 27k on it,,,
My 06' F-350 has almost 47k, on it,,,Never been to Nova-Scotia,,,once,,,,Strange how things are!
Old 11-11-2009, 07:29 AM
smlford's Avatar
smlford smlford is offline
smlford has a good reputation on FTE.smlford has a good reputation on FTE.
Sorry to be a spoiler here but the fact that these trucks can run that fast in a straight line does not mean you should.
If you had to swerve unexpectidely in an emergency manuver you'd be screwed.
8000# trucks with a high center of gravity are not designed to safely run at that speed.
Old 11-11-2009, 07:57 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
SMLford beat me to it!
NOTHING that heavy can move at that speed on a public roadway safely. Especially something built like a Ford SD! Relatively imprecise recirculating ball steering, high COG, large tires, solid front axle, and tires that aren't made for high speed handling all combine to make a dangerous vehicle at those speeds.
It's a truck, not a Mustang!
Old 11-11-2009, 08:43 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Yes. Don't run that fast. When the truck is loaded or if there is a trailer you always should anticipate your turns/lane changes by turning the wheel very slightly until you FEEL the transfer of weight shift to your outside, then after you know the weight has been shifted go ahead and make your turn. Not sure if I explained right but you know what I mean if you pay attention to things.
If I am turning left I always load my right side before completing the turn, opposite for right turns. It's the shifting of weight from neutral to one side or the other that gets things out of shape and once you get 8K or more moving in the wrong direction it's twice as hard to get it settled down without wiggling all over the road. Sudden movements = Bad things.
Old 11-11-2009, 08:48 AM
msgtord's Avatar
msgtord msgtord is offline
msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.
Along the Southern Border , alot of the Border Patrol vehicles are lifted F250's with big tires. Those guys drive 90-95 all the time on a narrow 2 lane road. I am waiting to come up on one that had a blow out and rolled it.
Old 11-11-2009, 09:26 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I've had my SD well over 100mph a few times and its rock steady.(Speed Limter is removed) I was empty and it was a short burst.(little to no wind and traffic) No way I'd run a truck loaded like in the pic that fast especially in a wind. A heavy wind can throw the SDs around a bit especially if its a side wind and your going fast.
Old 11-11-2009, 09:39 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
SO is it worse he is allegedly doing 90 or you are taking pictures of it while doing at least 80? And yes a Ford Superduty can move safely at 90mph in various situations, if not it would have a speed limiter much less on it.
Old 11-11-2009, 01:54 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
There is a point where you go over a certain weight, and either the frame is on the axle directly, or there's just way too much weight behind the rear axle, and the rear end sways all over the place. That particular truck either has something wrong with it, or a whole bunch of steel plate in the exact WRONG spot - as in, on the right side of the bed, way behind the rear axle. Or welding rods, or something else. Even though it might not be over the max weight you can carry, it's in the wrong spot. It should be centered, at the front of the bed, and then it would be just fine.
As for cruising at 90, I do it. Often. With a decent load. Is it less safe than 70? Sure. But I don't do it with other traffic around. If a deer jumps out in front of me, I'm going to just go straight into it
That truck, like I said, either has serious weight in the wrong place, a bad set of tires like D's or even C's with too much weight on them (although that pic shows they are not squished), or some other suspension problem like a broken leaf spring pack.
Finally got to tow something LM14 2009 - 2014 F150 7 07-13-2014 09:54 PM
Hypermilers thread David85 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 250 05-01-2014 09:42 PM
2.5L 4 cyl. - 33 MPG HWY; 85 MPH; & Playing with gas mileage Torky2 Escape & Escape Hybrid 2 05-22-2012 12:13 AM
Some thoughts on measuring MPG for a PSD... ernesteugene 1999 - 2003 7.3L Power Stroke Diesel 21 06-09-2008 08:42 PM
Trailer Wind Resistance. V-nose vs. Floe Protektor/ Triton 2KF natewoz 1999 to 2016 Super Duty 1 05-26-2008 03:39 PM
Tags
6, brakes, bronco, country, duty, install, rough, shake, side, stuff, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
