Bars Rad stop leak, bad or good idea?` - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-10-2009, 01:11 PM
mibson mibson is offline
mibson is starting off with a positive reputation.
I had a minor leak in the bottom of my rad, by the drain ****. I used bars stop leak. Was this a bad idea? Ive heard mixed reviews of using these rad stop leak products.
Also, I added the stop leak, perhaps, when the rad didnt have enough rad fluit drained out, so alot of it seems to have pushed out back into the overflow. Should I use a suction device to get this out of the overflow?
It did seem to stop the leak...
I did flush the rad about 2 weeks before using the stop leak...
Thanks for any help.
Old 11-10-2009, 05:25 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
I have also used it, one guy at a shop said it was a mistake as it will cause the heater core to clog! I have not had any problems with mine however.
Old 11-10-2009, 06:52 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Well, let's see, you've done the cheap repair, but it's not really a repair. You put something foreign into your cooling system. Something that blocks the flow of coolant, you don't decide where this foreign material blocks the flow of coolant, physics does. The proper way to fix your radiator leak is to fix the radiator leak, not create another problem.
So, it's a bad idea.
Old 11-10-2009, 11:30 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
Talking
It's a temporary fix until you pull the radiator and have it repaired properly. Leaking radiator equates to a very hot engine and big bucks down the road.
Rog
Old 11-11-2009, 06:42 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
the best thing to do is replace the radiator. however I look at each situatin differently, what year is the car, is it on it last leg and you just want to get another 6 months out of it , etc etc, you did not post the info of the actual truck. if the truck was 2 years old I would not put it in, like an earlier post said you are adding a clogging agent into your enine the stuff can go anywhere. I have used it on a 12 year old f150 with 180k on it nd it workd for me and did not clog up the heater core I drove it for at least another year. the sold it
Old 11-11-2009, 10:24 AM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
I've used Stop Leak before and while it stopped the leak, it also seemed to reduce the cooling capacity of the system and I started to have overheating problems afterward. Since I live in Southern California, and you live in Canada, you many never have this problem.
But it would be best to consider Stop Leak as a temporary fix only. Sooner or later the radiator will have to be repaired or replaced.
Old 11-11-2009, 11:29 AM
Replace or repair rad
I should have trusted my gut and not used it. Anyway , the rad appears to be in good shape with only this small leak (that has now stopped). How do you determine if the rad should be replaced or fixed?
And how do you fix a leak in a rad?
Old 11-11-2009, 11:36 AM
You can bring it to a radiator repair shop and they can fix it but a lot of the time you might be better off just buying a new one because the repair might cost almost as much. Again. What year is your truck and how many miles are on it
Old 11-11-2009, 12:18 PM
Truck info
Quote:
It is 1989 with only 97 000miles, Im hoping to keep it running for years. It was driven 1-2 a month to the grocery store by an elderly woman...
Old 11-11-2009, 12:49 PM
Sounds like a nice truck. Next time post the question. See what peeps say and then do what you think. I looked up your rad on rock auto and they had 3 for less than $100. My biggest concern would be plugging the heater core. However on your truck I think they are real easy. On rangers after 94. You have to pull the steering wheel and dash. You should update your signature with as much info as possible. It helps with diagnosis. I know what someone is thinking this guys signature is not updated. I have tried 3 tims and it would not take. A mod is trying to help me
Old 11-11-2009, 02:01 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Bars leak is a good product, it may reduce your flow in the heater core, but has not in my experience cause blockages elsewhere................Some of the other "miracle" stop leaks also plug up heads and water jackets.............stay away.
Old 11-12-2009, 04:47 PM
19704X4F250's Avatar
19704X4F250 19704X4F250 is offline
19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all
I use pepper for a temporary repair. Just buy a small can at the grocery and dump it in. Won't harm anything either. It won't work for head cracks but its just fine for radiators and heater cores.
Old 11-12-2009, 05:28 PM
Really. How much and how long will it hold? Why would pepper work?
Old 11-12-2009, 09:31 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
I learned the black pepper trick while working in the salvage yards we would buy a drivable wreck at auction and some would have radiator leaks put a couple of tbps of pepper in drive them to the yard. it works well.
Old 11-12-2009, 09:38 PM
kawa's Avatar
Talking
Now that trick is nothing to Sneeze at!
Rog
Coolant disappearing?!?!? snaponprofile Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 34 05-28-2015 02:45 PM
Factory 302 Radiator help axelgawn 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-24-2015 01:43 PM
Overheating six MFJ 1987 - 1996 F150 & Larger F-Series Trucks 29 09-08-2014 12:46 AM
Rad Questions Cameo 57 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-29-2014 03:35 PM
94 f250 gas rad & 94 f250 diesel rad enosez 1987 - 1996 F150 & Larger F-Series Trucks 0 04-02-2013 03:46 PM
Tags
bad, bars, cock, core, drain, ford, good, heater, leak, pepper, rad, ranger, reviews, stop, stops
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
