Alt. Belt Tension--I Got "Rotundaed" Again--LOL
Hey all,
I'm replacing the alternator on my '97 F-250, 7.5L (see signature). It is a manually-tensioned belt, as the auto-tensioner takes care of the other belt (the 7.5L has two belts, unlike the 4.9).
I am using my recently-acquired FoMoCo factory shop manual (from Helm--that purchase is a saga I will relate when I have time) and when I went to look up the spec for the alt. belt tension, I got this:
"Use Rotunda Belt Tension Gauge (# blah blah blah) or equivalent, and set to specified tension."
Except I don't have one of those--and I'm starting to hate the word "Rotunda," as it denotes all of these FoMoCo-only tools that I don't have.
What's worse is, they don't even list the lbs. of tension for this spec., so I could at least estimate it myself.
So, even though this is a serp belt, can I use the tried-and-true (for V-belts) method of 1/2" of belt deflection, when pressed "pretty hard" with a thumb, in the middle of the longest span? I actually set it to 5/8" deflection, using this method, and it still feels looser than the auto-tensioned belt which drives the power steering, AC, etc.... But I don't want it tighter than necessary, as I don't want premature accessory bearing failures.
Thanks.
Big Six
Thanks.
Big Six
Padlock
11-04-2014 05:59 PM
jtharvey
19
02-26-2008 11:40 PM
madpogue
01-28-2008 06:05 AM
