Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-10-2009, 03:58 AM
Beene Beene is offline
Beene is starting off with a positive reputation.
How long before the alternator will read 14V?
I've got an '03 F350 PSD that seems to have a charging problem. Right after I bought the truck it would turn the ABS light on first thing in the morning. Once the RPM's came up it would go off but I took it into the dealer anyways. They said it was a dead alternator and replaced it which fixed the problem. That was about a year ago. Right after I picked it up I checked the charge voltage with a multi-meter and it was usually 12.6-13v at most but since it was just replaced I figured it was normal for these trucks.
After recently experiencing an almost dead battery, and not wanting to risk that in winter, I replaced them both with brand new Energizer ones from walmart that read 12.6 and 12.7 no load. Even with new batteries, when I start the truck It will drop to about 11.5V and slowly creep back up but doesn't go past 13V even with raised RPM's. It seems to crank fine but is this normal?
It's too snowy here now to drive my summer car so I can't really be without the truck to pull the alternator to have it tested and I'd just replace it but all the one's I'm seeing online seem to be over $400. I heard that due to the massive drain from the glow plugs and starter and whatnot that it takes a while for all that to shut off and the voltage to increase again. How long?
I've searched but not really found any exact answers for the problem, I don't have a spare alternator to try and I'd rather not spend the money if I don't have to this close to christmas. I cleaned up both sets of posts when I put the new batteries in(they were pretty coroded) Any suggestions?
Thanks,
Beene
  #2 (permalink)
Old 11-10-2009, 09:57 AM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Have to say I agree with your concern. You could, for instance, have a burned out diode in the alternator that would permit it to continue functioning, but with reduced output. Then each time you drive a short distance the batteries wouldn't fully recharge.
Frankly, if you have snow on the ground, I'd find a way to get the alternator in for testing even though its inconvenient.
__________________
2005 F350 V10 6spd dually, 15K receiver. No 4WD, no LS, no A/C, no special cab - just a lean mean towing machine!
  #3 (permalink)
Old 11-10-2009, 01:17 PM
benspeedbarn benspeedbarn is offline
benspeedbarn is starting off with a positive reputation.
Ours never does on our either of our 2004 6.0 PSDs. They are always in the low 13s. I replaced the one, because it was showing around 11.5 while running. Brand new it was still only charging about 13.3 Not sure if it has to do with the dual batteries or what. But it's been going fine for a while like that. The truck runs a plow, and it has plenty of juice for that, and starting on cold days.
  #4 (permalink)
Old 11-10-2009, 04:21 PM
Maybe the most convenient thing to do would be to write down your battery voltages and take a few more readings every few days. If the voltage doesn't drop at all over a few weeks, then benspeedbarn is probably right and its normal...
__________________
  #5 (permalink)
Old 11-10-2009, 04:32 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of
It's generally thought that the glow plugs stay on for at least 2 minutes after starting. In cold weather, I think it might even be longer than that.
The alternator is turned on by the PCM in these trucks, and it does not turn the alternator on until the glow plugs have turned off. This is to protect your alternator from the very high current draw of the glow plugs.
I think I would make sure the truck had been running for a safe time period, lets say 10 minutes to be generous, before you check the voltage output.
Lastly, are you sure you only have 1 alternator? Two alternators is a common option.
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.'08 Diff Cover Fleetwood Pioneer,23'x5,200#
  #6 (permalink)
Old 11-10-2009, 04:37 PM
Thanks for all the help guys!
I will try checking over a period of a few days and I'll make sure the truck has been on for atleast 10 minutes. I install remote starters for a living so I know that the plugs do stay on for a much longer time then the light and we usually go by the 2 minute asumption. I'll also check for a second alternator although I don't know how I would have missed one but the truck was a plow truck before so it's possible.
How hard is it to add a second alternator? I do alot of single track riding out in the middle of nowhere so I have a lot of attitional off road lights for when I'm leaving a trail late and I have a descent sized stereo in the truck. I'm also a fan of having something overbuilt so it won't leave me stranded so I'd just prefer the peace of mind of a "backup" alternator if one were to fail.
Thanks,
Beene
  #7 (permalink)
Old 11-10-2009, 04:45 PM
bpounds's Avatar
2 bit Californian
The standard single alternator is up high, on the passenger side, and you definitely will find that one. The second, if it has it, will be down low on the same side, and you have to look for it.
I've never heard of anyone adding a second, so I don't know what it would take. But I'm sure you would have to have the dealer program the truck to operate it.
I've never quite understood how they program the logic for the second alternator. It seems like it just sits there doing nothing, until the current draw is more than the primary alternator can handle, and then it kicks in. I've heard of guys still having dead batteries, just because the primary died and the secondary still didn't kick in. Doesn't make a lot of sense to me, but I am not sorry that I don't have the second one.
I don't think a secondary is any protection against a failed primary. But the secondary is good for tow trucks or ambulances where they need a lot of output.
__________________
Folks call me Bill.
  #8 (permalink)
Old 11-10-2009, 05:19 PM
bryyce62's Avatar
bryyce62 bryyce62 is online now
<------My Stinky Girl
bryyce62 has a very good reputation on FTE. bryyce62 has a very good reputation on FTE. bryyce62 has a very good reputation on FTE. bryyce62 has a very good reputation on FTE.
Without getting in the way of your issue, make sure that the battery(ies) in your volt meter are fresh if it is DC operated.
__________________
'03 Lariat CC 4X4, FT valve body, Y-pipe mod, Bilsteins, 500Wx5, Stealthbox, FIPK, Magnaflo, '08 diff cover
  #9 (permalink)
Old 11-10-2009, 09:48 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
I didn't see where we specified 7.3 or 6.0. It shouldn't make a difference but is good to know.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #10 (permalink)
Old 11-11-2009, 12:26 AM
QwkTrip QwkTrip is offline
QwkTrip is gaining momentum as a positive member of FTE.
Quote:
You are on the right track with your idea. The basic job of an alternator is to maintain system voltage at a specific level. It does this by turning on/off at high frequency and the duty cycle controls the amount of charging current. This also causes the voltage to constantly cycle above and below the target charging voltage. In a dual alternator application, one alternator will have a slightly higher voltage set point then the other due to manufacturing tolerances. The alternator with the higher set point will be working harder then the other alternator. How much harder it works will be dependent on how much overlap there is in the range of voltage each alternator has around the target. If the manufacturer has really tight voltage tolerances then the second alternator will be contributing something most the time. If the tolerances are not very tight then you could end up with one alternator just along for the ride until electrical loads exceed charging capacity of the first.
Tags
14v , 2nd , 60 , alternator , charges , dead , draw , duty , f150 , ford , long , normal , range , super , truck , voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
