'67 F100 - Relocate the Gas Tank - Ford Truck Enthusiasts Forums
Texas Chapter Join Chapter, Leader: LibTimothy
Old 09-12-2002, 09:11 AM
Crowbar65 Crowbar65 is offline
Crowbar65 is starting off with a positive reputation.
Old 10-20-2002, 05:34 AM
GolferSA's Avatar
GolferSA GolferSA is offline
GolferSA is starting off with a positive reputation.
To free up the room behind the seat, I've been considering building (ok, having built) a box in the bed, just large enough to hold the gas tank (standing upright the way it is behind the seat), with a lift up lid to access the filler spout and a locking gas cap for peace of mind. Think of a "between the bed rails" diamond plate toolbox, 8.5" deep by 65" wide by 18" tall, standing upright. Minimal work to re-route the fuel lines and electrical, Plus you get to keep your sending unit, you only lose 8.5" of bed space, and my spare can stay hanging underneath out of the way. I would leave the original filler neck in the cab, and just cap it off inside, to retain the original look of my truck.
Thoughts?
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
http://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
golfersa@netscape.net
Check out my gallery!
Old 10-21-2002, 01:08 PM
Rosati's Avatar
Rosati Rosati is offline
Rosati is starting off with a positive reputation.
You may find that your tank will get water inside from condensation. If the tank is cool and the sun comes out, it will warm the outside of the tank causing condensation on the inside. If it was under the truck, your bed would block the sun. Also, how are you going to mount it? Be sure to isolate it from metal to metal contact. Hope I helped.
Old 10-21-2002, 06:18 PM
GolferSA's Avatar
Ken...
Not trying to be a smart*ss, but help me out.
Inside the cab in the hot sun, or inside the box in the hot sun... inside the cab it's attached directly to the metal back wall, inside the box it would be attached to the back metal wall. What's the difference?
FYI I was going to use whatever mounts are inside the cab inside the box, so it would be mounted the same way... anticipated needing some rubber bumpers to insulate the tank... appreciate any feedback.
Thanks!
GolferSA
Old 10-22-2002, 09:24 AM
Rosati's Avatar
No offense taken or implied. Just trying to help consider all of the angles. The metal to metal contact I was refering to relates more to exposure and rust than anything, the tank doesn't get wet in the cab.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 12:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 01:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 09:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 10:13 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1964, 1967, 64, 65, cab, f100, ford, gaas, gas, relocate, relocation, seat, tank, texas, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
