Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-09-2009, 05:22 PM
Aero-fan's Avatar
Aero-fan Aero-fan is offline
Aero-fan is starting off with a positive reputation.
Ordered rockauto tune up parts for 97 Aerostar: questions???
I recently purchased tune up parts for my 1997 3.0L Aerostar 4spd automatic with 30,000 original miles, including:
1) Spark plugs (6) Autolite double platinum part no APP104
2) Motorcraft Factory Plug wire set part no WR4105
3) Blue Streak Distributor Cap part no FD169X
4) Blue Streak Ignition Rotor part no FD308X
All of the parts were ordered from the rockauto site using their convenient pull down menu. Now that the parts have arrived, I noticed the distributor I received looks like a conventional distributor with a circular base. I took a look under the hood and my "distributor" is not a distributor at all. It's a rectangularly shaped coil which has all the spark wires emanating from it. I'm assuming it has no rotor inside and my vehicle does not appear to be equipped with a conventional distributor/rotor system. The plug wires I received appear to be correct, they have the special looking connectors on them (with two pronged levers on the ends that connect to the multipoint coil).
Questions:
1. Why does the rockauto parts system indicate that the 1997 American model Aerostar with the 3.0L use a conventional circular distributor cap and rotor? Was there a 3.0L 1997 model that used a conventional cap/rotor system? Will they give me a hassle or charge me shipping to return these items? (first time I've purchased from rockauto)
2. Is the coil cap on my aerostar replaceable or do you simply reuse it everytime you replace the plugs and wires?
3. Are the APP104 Autolite plugs right for my 3.0L Aerostar?
4. The Motorcraft wires appear correct, but I noticed on the plug ends, 4 of them have black ends and 2 of them have gray ends. Is there some special reason that 2 of the ends are gray?
Thanks in advance for any advice or help...
__________________
1997 Aerostar Extended 3.0 2WD, 28K miles
  #2 (permalink)
Old 11-09-2009, 06:49 PM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is starting off with a positive reputation.
1. I've a feeling that was an error in their electronic catalog. A lot of the 3 liter engines came with a real distributor; I don't remember when they switched to distributorless (EDIS), but certainly yours is of the later design. You will probably have to pay shipping to send it back for a refund. If the cost of the cap is not much than the shipping, I would just keep it, and try to sell it to someone locally. And send an email to Rock Auto customer support in complaint.
2. Your EDIS uses a multi-port coil set, and should not have any replaceable parts. You should not have to do anything with it unless it has a problem, like arcing to ground through a broken insulator. Then it's the whole coil pack that has to go.
3. I don't know the correct model, but I do not believe you should have to replace the plugs any sooner than about 60,000 miles. Check the existing plugs to see how they are, and replace if they are heavily worn, fouled, or otherwise not working.
4. Don't know the significance of the boot colors, but again, if you're not having problems with the existing wires, I would leave them. You check those by running the engine at night, and look for arcing along the wires or boots at each end.
  #3 (permalink)
Old 11-09-2009, 08:07 PM
taurus8's Avatar
taurus8 taurus8 is offline
taurus8 is starting off with a positive reputation.
As someone who tends to keep his cars a long time (put on 200,000 on an '87 VW Fox, 300,000 on a Nissan NX) I didn't replace spark plug wires at all on the VW, and only just now on the NX when I felt it was driving a bit lethargically on about 250,000kms. I replaced the wires on the Aero when I bought it because I found that the engine was completely original, except for the spark plugs.
Spark Plugs...maybe once every 2 years depending on the condition I fiund them in. Most important thing is to get to know your vehicle. I keep track of the mileage (kilometerage?!) and if that starts to go down, or I notice any hesitation etc., then I'll perform some sort of tune up. I do bring it in once a year for my mechanic to check the chassis out and ensure all is up to snuff.
The very most important thing to do in longevity of a vehicle is to keep the fluids changed regularly. And the filters (air, oil and to a lesser degree transmission) as well.
__________________
John.1992 LWB Aerostar XL, 4.0L, 340,000kms
  #4 (permalink)
Old 11-09-2009, 09:35 PM
Aeroman59's Avatar
Aeroman59 Aeroman59 is offline
Aeroman59 is starting off with a positive reputation.
Quote:
Originally Posted by Aero-fan View Post
Questions:
97 Aeros had EDIS ignition system, no distributer, instead had a Camshaft position sensor in the same drive hole.
Coil cap? are you talking about the rubber boots on the wires? They should be included with the wire set, you just plug them into the coil pack.
Sounds like they are the ones, mine used AGSF 32FM Motorcraft but Autolite (Honeywell) are OEM for Ford.
My original wires were the same as that, they also lasted 12 years & were still in good shape when I finally replaced them. I only did that because I had a strange misfire; which turned out to be a loose plug ( My fault). Your Aero also has OBD2 diagnostic system & EEC V computer to run it. The 4R44E transmission uses electronic overdrive & solenoid shift clutches throughout & engine runs best on 5w30 or 5w20 oil. This engine is one of the most reliable Ford engines to be built. You could get 500,000+ kms out of it.
You are welcome.
Aeroman.
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 320,000 kms & going strong !
When describing the 96 Vulcan engine, the word Bullet proof is not too much of an exageration !!! Just a little TLC goes a LONG way.
  #5 (permalink)
Old 11-09-2009, 11:07 PM
Aero-fan's Avatar
Thanks guys. So the 97 aero was made with the normal distributor system too? As far as replacing the wires and plugs, the van only has 30,000 original miles on it. It seems to get mileage that's in the 15 to 17mpg zone driving pretty gingerly around town and some on the road. I think it should do better from what I've heard (epa says 23mpg highway). So I'm thinking replacing the plugs and wires might be a good idea. The wires are almost 13 years old now, and I'm not sure if the plugs are double platinums or not. If not, 30K miles might be enough to wear them down to the point where replacement or regapping might be warranted. And if I have to take those things out, they're getting replaced considering what a pain in the ass it is to get them out.
__________________
  #6 (permalink)
Old 11-10-2009, 12:38 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar is starting off with a positive reputation.
Yup, you got the right stuff except for the distributor related stuff. I think the '97 was the first year of the EDIS waste spark system on the 3.0L. Other economy related items include cleaning the MAF sensor and replacing the O2 sensors at 80,000 miles.
I learned the other day that doing plugs on the Aerostar is a piece of cake compared to the 8 plug head on a 2.3L Ranger. Getting the old wires off was a total pain. The new wires were updated with special plastic hooks so that you can grab them, but that didn't help me with this job.
  #7 (permalink)
Old 11-10-2009, 09:57 AM
Aero-fan's Avatar
Thanks again for the info. How might I find out if the MAF sensor is dirty? And how do I properly clean it? I've heard it's very delicate and you have to be real careful with it. Any other ideas on helping to ensure my Aero is running in top form? Not really familiar with the Ford EFI system or how to keep it fully tuned.
__________________
  #8 (permalink)
Old 11-10-2009, 10:06 AM
To clean the MAF you will need security torx bits. You then pull the element out and spray it (no brushing or touching the element at all). There are specialized cleaners for this. For maximum life, I recommend cleaning it every time you replace the air filter.
  #9 (permalink)
Old 11-10-2009, 05:05 PM
93nighthawk's Avatar
93nighthawk 93nighthawk is offline
93nighthawk is starting off with a positive reputation.
Thanks guys. So the 97 aero was made with the normal distributor system too? As .
No it was not Aero-fan, they went to a DIS system in about '93 with the 3.0L in the Aero.
__________________
'97 Ford Aerostar AWD 4.0L v6 AT 84k mi
'07 Ford Taurus SE 3.0 Vulcan ATX 42k mi, Last of the original Tauri
My Car Domain
The Possum Aero-Van!
  #10 (permalink)
Old 11-11-2009, 02:18 PM
94MustangGT's Avatar
94MustangGT 94MustangGT is online now
1994 Ford Mustang
My Garage
94MustangGT is starting off with a positive reputation.
In addition to your other parts, change the fuel filter. It's about as easy as it gets on these Aero's. Also wouldn't hurt to clean out the throttle body, and throw in a new PCV valve.
__________________
96 F150 XLT - RC/SB - 351 - E4OD - 4X4 - 3.55's w/Rear LSD - Handling Package - Towing Package w/Super Cooling - Warn Manual Hubs - 31" BFG AT's
94 Mustang GT - 302 - 5speed - Black on Tan Leather - Bullitt Wheels - Bolt-Ons - 9.2 @ 77.4
  #11 (permalink)
Old 11-22-2009, 08:56 PM
Aero-fan's Avatar
update...
Well I contacted rockauto and informed them the distributor and rotor they sent me was not right for my vehicle. The young guy on the other end was polite but insistful that the parts were for my vehicle and that their database is very rarely wrong. I then informed him that I carefully inspected my own vehicle and that it clearly did not have a normal distributor system, but instead had a distributorless ignition module. I also inspected my 1997 Ford Aerostar factory shop manual for a 3.0L Aerostar, and it did not mention nor display any normal distributor/rotor system, only the distributorless system equipped on my vehicle. He insisted they must have been offered in addition to the distributorless system and basically assumed a superior knowing tone that was suggestive I was just some "behind the times" old guy (I'm in my 40's lol) that doesn't understand the extreme accuracy of his computerized database system.
I recently experienced this same thing at a local NAPA store when ordering parts for my Honda Civic. I told the 20 year old kid behind the counter I had a 2.0L VTEC engine in my civic and he insisted it couldn't be a VTEC because his computer did not list it for that year and displacement. I tried to explain to him it was VTEC and that it says "VTEC" on the valve cover, "VTEC" all through my owners and factory shop manuals and a big sticker on the side of my car says "VTEC". Nope, he'd hear none of it, and tilted the computer screen toward me and showed me where under the 2.0L engine it did not specifically say "VTEC". I scowled at him and was beginning to lose my temper, and suddenly he seemed to sense this and backed off in a patronizing tone (probably fearing I was going to summon his boss) saying more or less "it's ok old man, even though you don't know what you're talking about, I think we can still help you out".
I guess this is a normal part of getting older. And I accept it, maybe I was the same way on some level when I was their age. But goddamn it's aggravating at times. I suppose it'll only get worse with age if I let it get to me. I just wonder what will happen to kids of their generation if there is some kind of setback in our civilization where technology is no longer constantly at their fingertips as it is now. Or if they'll ever understand the ill placed wisdom of putting so much blind faith in computers and what they tell us.
Anyway, the guy at rockauto requested that I send him pics of my Aerostar manual to prove that the '97 came with the distributorless system. I did and only then was sent a return authorization number. I still have to pay shipping back. Buyer beware, computer kidz don't understand us old guys and our "senile" ways.
__________________
  #12 (permalink)
Old 11-23-2009, 02:13 AM
Hey the PCV valves for my '94 Aerostar are all wrong in Rockauto's database. The Motorcraft one is correct, but every other one is wrong. They should the PCV valve as a one piece with the hose fitting coming out at 90 degrees, when in reality, the hose comes in from the top. The Motorcraft came as a two piece so that it worked either way.
Tags
aerostar , auto , coil , pack , parts , replace , rock , shipped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
