Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-09-2009, 12:26 PM
mt534 mt534 is offline
Garage is empty, add now
mt534 is starting off with a positive reputation.
534 GOVERNOR SETTING
Hello, I am new to this web site. Found site while looking for information on the Ford 534 SD engine. I have a 1972 National motor coach (similar to a wonderlodge). It has a 534 and is mated to an Allison MT 42 6 speed automatic transmission. When we bought this coach, the bus itself is in very nice shape inside and out. Engine ran but poorly. I have since torn motor down and completely rebuilt it (wanted to keep it original). Engine was bored .030 over and everything in it replaced. I am using an old Chiltons book for all specs and information. It has been very useful up to this point. What I need is the maximum RPM setting to adjust the governor to. I am inclined to think it would be in the 3400- 3600 RPM range. With my time and money invested in this engine I want to set it to the factory spec. Any help would be greatly appreciated. Mark
  #2 (permalink)
Old 12-04-2009, 10:31 PM
401477434 401477434 is offline
401477434 is starting off with a positive reputation.
It is spose to be set to 3400 rpm, you could probably run it to 3800 rpm without hurting it, but its probably good to keep it at factory specs, you can go to google and type in (534 v8 wiki) it should come up with a wikipedia page on the 401 477 anf 534 engines, it tells the max rpm there, ive seen it other places too.
  #3 (permalink)
Old 01-23-2010, 12:53 AM
mikehallbackhoe mikehallbackhoe is offline
mikehallbackhoe is starting off with a positive reputation.
I have a 477, and while the redline is 3600 rpm, how high can you safely rev these engines ?
  #4 (permalink)
Old 01-23-2010, 10:51 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Uhh, 3600. You run the risk of throwing a rod even at 3600, so I'd keep it under that.
  #5 (permalink)
Old 01-24-2010, 09:37 AM
thanks, the reason I ask is the mechanic who is installing a new clutch for me told me it would not hurt to rev it to 4000 rpm for short bursts. I want this truck to last, it has just under 100,000 miles , and I don't take it over 3500 rpm.
  #6 (permalink)
Old 04-29-2010, 11:36 PM
on the other end of the power scale, how low can you run this engine under load, without lugging it?
Tags
1972, 534, ci, engine, ford, governor, governors, max, motor, reman, rpm, specs, truck, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
