Drive shaft shop? - Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
Drive shaft shop?
Old 11-09-2009, 10:59 AM
99F-350CrewCab's Avatar
99F-350CrewCab 99F-350CrewCab is offline
99F-350CrewCab is gaining momentum as a positive member of FTE.99F-350CrewCab is gaining momentum as a positive member of FTE.
Drive shaft shop?
Looking for a drive shaft shop to rebuild my front drive shaft in my 99 F-350. Anyone have any suggestions of a good shop in the Peoria, IL area?
Old 11-19-2009, 03:24 AM
Links56's Avatar
Links56 Links56 is offline
Links56 is starting off with a positive reputation.
The Drive Shaft or axle? Just needs new U joints? I have a Shop in Galesburg.
Old 11-19-2009, 08:51 AM
The slip joint in the front drive shaft is loose. The U-joints seemed ok, but I'd have them replaced while I had it out. Is this something you could do?
Old 11-19-2009, 02:24 PM
Links56's Avatar
I'm positive it is. If you haven't found a decent shop in peoria. Let me know if you want to have it checked out.
Old 12-13-2009, 08:55 AM
Saw the PM you sent, but like you I didn't notice it for a while. Shoot me your number or email. I'm hoping to get this fixed before christmas if I can. Thanks.
Old 01-29-2010, 07:19 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
did you get your driveshaft replaced or repaired yet?
Selling my truck fuelman 1994.5 - 1997 7.3L Power Stroke Diesel 19 01-18-2010 09:06 PM
running flathead 55 f350 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-26-2008 10:15 PM
1979 crew cab in Peoria toddn78 Arizona Chapter 3 06-10-2007 05:14 PM
1997 F-150 4x4 Light Won't Go Out Beerstalker 1997 - 2003 F150 3 01-28-2007 10:59 PM
New Peoria area 98teal250 Illinois Chapter 3 09-18-2006 10:16 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
delaware, drive, driveshaft, ford, front, il, joint, loose, peoria, rebuilding, shaft, shop, shops, slip, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
