Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-09-2009, 08:26 AM
bhami8287 bhami8287 is offline
bhami8287 is starting off with a positive reputation.
Swapping out an instrument cluster in '78 F-150....Have a question.
I recently purchased an instrument cluster from a '79 F-250 to replace my old one. Should everything work as normal in the new cluster just by plugging it in or will it require some electrical work??
Thanks in advance for any help.
Ben
  #2 (permalink)
Old 11-09-2009, 08:45 AM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
If both trucks had a charge gauge and oil pressure gauge, then it will work. Or, if both trucks had an "ALT" light and "OIL" light, it will work. If one truck had gauges and the other had lights, it won't be a direct swap. The alternator wiring harness and some of the wiring up to the cluster will have to change.
By the way, welcome to FTE!
  #3 (permalink)
Old 11-09-2009, 09:05 AM
fmc400,
thanks for the info. If I remember correctly, they both had lights for Oil and Alt. The only differences were the new one has 100 mph speedo (old was 85) and the high beam light is off to the side rather than the top of the cluster.
Ben
  #4 (permalink)
Old 11-09-2009, 07:40 PM
firstonraceday's Avatar
firstonraceday firstonraceday is offline
firstonraceday is gaining momentum as a positive member of FTE.
The 79 cluster should be 85 mph speedometer and have the bright indicator at the top of the speedo. The description sounds like a cluster from a 76 or older truck.
I had a 74 F100 with a cluster like you described except all gauges. My 77 has a cluster with the high beam indicator at the top. It also came with a 100 mph speedo (I have since had to change to speedo out, it now has an 85 mph speedo).
__________________
Jason
2005 F-150 XLT SuperCrew, 5.4 w/Auto, 3.55LS
1993 F-150 300 I-6 w/5-Speed (Traded for the above 8/6/2005)
1977 F-250 351M w/T-18 (Rebuilt at 315,000 Miles)
2008 Escape Limited w/3.0L V-6 (Wife's)
  #5 (permalink)
Old 11-09-2009, 07:52 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
1974 Ford F-100
My Garage
Bullitt390 is gaining momentum as a positive member of FTE. Bullitt390 is gaining momentum as a positive member of FTE.
I agree the description is of the older "gauge" version. Not sure, but my memory is telling me the high beam light will create problems swapping one for the other.
Josh
__________________
1974 F100 Custom Styleside Dual Quad 428 Cobra Jet
  #6 (permalink)
Old 11-09-2009, 09:08 PM
fmc400's Avatar
I agree with the guys here; the "new" gauge cluster isn't really from a '79. Since that's the case, I can't say whether or not it will work. Originally the high beam indicator was on the side, until that spot got taken by a "fasten seat belts" light due to a federal mandate, at which time the light got moved to the top center of the speedometer. I can't comment on the wiring harness interchange between high-beam indicator positions; I don't see a practical reason for the connector being different but I really have no idea.
There are also some rare clusters with an economy indicator that were connected to a vacuum solenoid; I want to say they were only offered one year. I can't remember which one, but it was earlier than '78.
  #7 (permalink)
Old 11-09-2009, 09:14 PM
boggin79ford boggin79ford is offline
boggin79ford is starting off with a positive reputation.
i just got a 75 f250 parts truck and it has the low fuel economy light.
  #8 (permalink)
Old 11-10-2009, 12:26 AM
DeanG DeanG is offline
DeanG is starting off with a positive reputation.
If memory serves me correctly, there are differences in the wiring plug in between the older (76) and newer (78) clusters as previously mentioned. I put a 100mph cluster in my 78 also and had to change the wiring a little bit at the plug. Your best bet is to get ahold of a Haynes manual for 73-79 trucks. In the back they have schematics for all the model years so you can see the differrences. Once you figure out what does what at the plug, its pretty easy to follow the traces on the foil on the back of your new cluster to see what goes where.
  #9 (permalink)
Old 11-10-2009, 09:53 AM
Wow.....thanks for the replies guys. Looks like I have some work to do.
Thanks.
Ben
Tags
75 , 76 , 78 , cluster , clusters , f150 , f250 , ford , gauge , harness , instrument , lights , swap , truck , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
