Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
View Poll Results: which oil
stick with Valvoline 15w40 4 11.43%
switch to Valvoline 5w40 8 22.86%
switch to something else 23 65.71%
Voters: 35. You may not vote on this poll
  #1 (permalink)
Old 11-08-2009, 07:19 PM
Justin03PSD's Avatar
Justin03PSD Justin03PSD is offline
diesel n00b
Justin03PSD is starting off with a positive reputation.
winter oil
I have only had my truck since March, so this will be my first full winter with it. I have been using Valvoline Premium Blue 15w40. For winter I was considering switching to the Valvoline synthetic 5w40.
I am in the Kansas City area so we get pretty crappy weather, but it doesn't get crazy cold like it can further north. But unfortunately the truck does sit outside 100% of the time.
Think I should switch? Should I consider Rotella or another brand, or even 0w40? Thanks for your opinion.
__________________
2003 F-250 XLT 7.3 crew cab 4x4
Zoodad, 6637 covered by Pete, AIH delete, Magnaflow #17979 4" exhaust, DP Tuner F5 chip 40T / 80E / 120R, Autometer #3804 boost and #3845 EGT gauges
  #2 (permalink)
Old 11-08-2009, 07:23 PM
big poppa's Avatar
big poppa big poppa is online now
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
I think the full synthetic 5w-40 would be fine, its readily avail. at all your local parts chains or the Rotella at your local Wally World..You'll be suprised how much easier it is to start with those syn. in there.
__________________
Presure cookerMike 03 F-250 7.3 CC SB XLT 4x4 Roadside Help Network
  #3 (permalink)
Old 11-08-2009, 07:26 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 has a good reputation on FTE. Bigcat350 has a good reputation on FTE.
I use the Rotella 15-40 year around with no problems a lot of folks go to the 5-40 synthetic in the winter some run it year around also. I never needed to so I save that extra cash for a different type mod.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #4 (permalink)
crazy4wdracer crazy4wdracer is offline
crazy4wdracer is starting off with a positive reputation.
I'm going to switch to 5w40 Rotella in mine. Any brand synthetic should be fine. This is my first winter with my powerstroke but I have switched oil weights in my diesel tractor in the past and like the results so I'll be doing the same with the truck.
  #5 (permalink)
Old 11-08-2009, 07:36 PM
rednekrebel28 rednekrebel28 is offline
rednekrebel28 is starting off with a positive reputation.
Just switched to 5w-40 Rotella today. Even though its more expensive then the regular 15-40, I prefer synthetic any day. As for what brand, that shouldn't matter as long as its rated CI-4. Its noticeably better and quicker starts with the 5w-40 syn.
__________________
Russ
E99 Powerstroke 7.3, Bully Dog 4" Turbo Back, CCV, 6637, soon to have someones Tunes, Autometer Gauges, Marinco Mod.
  #6 (permalink)
jhand124's Avatar
jhand124 jhand124 is online now
jhand124 has a good reputation on FTE. jhand124 has a good reputation on FTE. jhand124 has a good reputation on FTE.
5-40 syn all year long, in my psd and equipment too. Much better starting in the winter.
__________________
Jason
E99, F350, CC, LB, 4"ex, AFE II w/ Pete's cover, ISSPRO gauges, TSI built trans, DP Tuner, EBPV brake w/T/C lock & LED. GP LED, True cool max 4739, CCK, S.S. HPX, in cab fuel pressure gauge, FPR shim, Bilsteins, X-code springs, cyo'ed Powerslots & Hawk pads, 247K on the clock. RHN
On work the bench: Intank Pump, Por 15 for oil pan, 140 IDM, .
  #7 (permalink)
Old 11-08-2009, 07:37 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation.
There's nothing wrong with Valvoline Premium Blue. You don't HAVE to switch from 15w-40, but the 5w-40 synthetic will probably help for a little quicker cold start and maybe a little less diesel racket when the engine is cold.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 320,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #8 (permalink)
Old 11-08-2009, 07:39 PM
ztodd377's Avatar
ztodd377 ztodd377 is offline
of FTE, RHN, and BEER!
ztodd377 is starting off with a positive reputation.
I actually run the 10W30 motorcraft diesel oil that ford recommends and I actually feel like the truck runs better than it did when I was using Rotella synthetic.
__________________
'01 F250 XLT ext cab, long bed, 4x4; 4" Diamond Eye turbo back exhaust; muffler delete; 6637 intake w/ custom cover from Pete's Filter Covers; I/C pipe foil delete mod; Transgo Tugger kit w/ Sonnax .427 valve; CCV mod; 3 pod A-pillar w/ ISSPRO boost, EGT, & trans temp; Zoodad mod; Mag-Hytec rear diff cover; 2 1/2" lift; Skyjacker Nitro shocks; Rancho steering stabilizer; Harpoon mod; DP Tuner w/ Stock, Hi-idle, 60T, 80E, and 120R; DBA 4000 Slotted Rotors w/ Hawk LTS pads.
  #9 (permalink)
Old 11-08-2009, 07:48 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
I run schaeffer synthetic 9000 series oil, 5w-40 I have for a year now, all last winter, all this summer and will all this winter. I also run the same oil in my diesel equipment. Solves many problems, including sluggish cold start.
__________________
00 F-350 Lariat 7.3 CC LB 4x4 3.73 l/s, 290k, pop-up GN hitch, 6637, foil delete, BD X-monitor, DP Tuner decel/40/80/140/drive-thru
99 F250 Lariat v10, ext cab, bone stock 315k miles, boss v-plow
99 F250 XLT 7.3 6spd 4x4 6637, DP tuner 40/80/120, 5 in exhaust 345k miles
  #10 (permalink)
Old 11-10-2009, 07:40 AM
Buzzard_Wing's Avatar
Buzzard_Wing Buzzard_Wing is offline
Buzzard_Wing is starting off with a positive reputation.
I am going to use Rotella 5w-40 for the first winter with a diesel... I have heard good things about it, especially in winter. One advantage of Rotella is it is commonly available.
I had Blackstone test the Motocraft 15w-40 at 3300 miles and I learned a lot... one is that the oil is still fine and two is that I have been changing my oil TOO often for the last 35 years! It was well worth the $22.50 and will save me a lot of time and money in the future.
__________________
2001 SD 7.3L PSD S-Crew Long Bed
  #11 (permalink)
Old 11-10-2009, 08:58 AM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
I run Mobil Delvac 15-40. I used to run Shell Rotella 15-40 until I got a deal on some Delvac, and my truck seems to like it better. I live in SoCal so the winters aren't what most would consider very harsh so I stick with dino usually. The few times I've run synthetic I've noticed the difference, but it is more costly. If I lived in a colder climate I would probably run synthetic during the winter months to ease the start-up stress.
Just my .02
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 195K+ Miles
AIH delete, In-Tank and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness, Zoodad, 6637, Foil Delete, Engine/CAC boots, Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
I can't decide which I like most about my truck...the noise or the smell.
  #12 (permalink)
Old 11-15-2009, 08:52 AM
nickj11 nickj11 is offline
nickj11 is starting off with a positive reputation.
Just switched from Rotella SAE 30 wt to Rotella Syn 5w-40. Noticably easier to start. Feel like it was a good decision, prolly should've done it sooner... Moving my drain intervals from 5000-6000, to 10,000, @ 10K, drop the filter- add 2 qts run another 5K until complete change @ 15,000. Also, use Baldwin Filters
__________________
2003 7.3 PSD FX4 Crew- 2.5" lift, 20" helo's, 33" Bridgestone Dueler Revo's, Bullydog cold air intk, roll-up bed cover, line-X, Manik SS grill guard w/ Hella amber fogs, OEM nerfs, ::soon to come programmer and 4"or5" exhaust, sound system
  #13 (permalink)
Old 11-15-2009, 09:48 AM
njneer1's Avatar
njneer1 njneer1 is offline
2000 Ford Excursion
My Garage
njneer1 is starting off with a positive reputation.
Rotella syn 5w-40.......all year long, 10k-12k intervals
  #14 (permalink)
Old 11-15-2009, 11:51 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Watch this...
2002 Ford F-350
Ponyboychris is a splendid one to behold Ponyboychris is a splendid one to behold Ponyboychris is a splendid one to behold Ponyboychris is a splendid one to behold Ponyboychris is a splendid one to behold Ponyboychris is a splendid one to behold
Rotella Synth. 5w-40 also all year long. I won't switch back.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #15 (permalink)
Old 11-15-2009, 12:08 PM
87 F-150 I6's Avatar
87 F-150 I6 87 F-150 I6 is offline
Duct tape and a hammer!
87 F-150 I6 has a good reputation on FTE. 87 F-150 I6 has a good reputation on FTE.
Quote:
X2 on that!
__________________
Andrew
2002 F-250 7.3L 4X4 CC SB AT /6637 mod/SS HPX/Stancore GPR/5" MBRP exhaust/Foil Delete/
Tags
350 , 5w40 , 73 , diesel , ford , oil , powerstroke , powerstrokes , rotella , synthetic , trucks , type , weight , winter , winteroil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
