94 f150 5.0 MAF and MAP sensors - Ford Truck Enthusiasts Forums
Old 11-08-2009, 07:29 PM
bcgdragon bcgdragon is offline
bcgdragon is starting off with a positive reputation.
Quick question. Searched but didn't find the answer.
I have a 94 F150 5.0. If it has a MAF does it not have a MAP? Trying to solve my rough idle/stalling problem.
Old 11-08-2009, 09:10 PM
brett12396f150 brett12396f150 is offline
brett12396f150 is starting off with a positive reputation.
Im 90% sure they are basically the same thing, you only have one. MAF=mass air flow MAP=manifold something pressure? believe they work the same though.
Old 11-08-2009, 09:57 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Well no.. they don't work the same but Brett is right a truck will only have one or the other. Are there any codes present?
Old 11-09-2009, 08:45 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
MAP: Manifold Absolute Pressure
Old 11-09-2009, 03:48 PM
@ conan--They do the same job basically right?
Old 11-09-2009, 05:48 PM
Conanski's Avatar
Quote:
Well.. lets just say they're related. The MAP sensor measures manifold vacuum and that's the only input an SD computer has to indicate engine load. The MAF sensor measures incoming air mass and the computer calculates load using that input but it also uses the measured air mass directly for other things.
maf conversion 78F460 1987 - 1996 F150 & Larger F-Series Trucks 6 02-08-2016 10:32 AM
Where is MAP sensor located on 94 F150 5.0? countryboywatts 1987 - 1996 F150 & Larger F-Series Trucks 10 01-02-2016 06:35 PM
A9l on a 94 5.0 Chumpy 1987 - 1996 F150 & Larger F-Series Trucks 10 11-20-2014 11:07 AM
Junkyard MAF Swap Hickfied 1987 - 1996 F150 & Larger F-Series Trucks 6 07-24-2013 08:25 PM
92 f250 351w MAF swap blackbeautyF1 1987 - 1996 F150 & Larger F-Series Trucks 6 10-23-2011 10:13 PM
Tags
1994, 50, absolute, air, conversion, f150, ford, maf, manifold, map, mass, pressure, sd, sensor, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
