Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-08-2009, 05:50 PM
rtazz17's Avatar
rtazz17 rtazz17 is online now
2002 Ford F-350
rtazz17 is starting off with a positive reputation.
fog lights not working
Truck is in signature.All of a sudden my oem fogs dont work.I took a volt meter to the connection where the bulb plugs in and no juice.Checked the fuse and its good.I get 12 volts or so at fuse for fogs..The foglight illuminator lights at the switch when I pull the switch.Is there a relay somewhere under the hood.All the relays in the fuse box checked out good and none of them in my truck guide were labeled for the fogs anyways.Im at wits end.Looked for 3 hours and cant find a thing.If all else fails how do I cut the wires at the fog lights and run wire to cab with toggle switch?I know I need a relay right?Im not familiar with hooking up relays...Any help would be appreciated...If I knew where the relay was I think I would find my problem...
__________________
Rob-2002 f350 crew cab w/82000 miles..4 inch mbrp xl series stainless steel exhaust,S & B cold air intake,bilstein shocks,skyjacker dual stabilizer,285/75/16 firestone destination a/t,2.5 inch hanger/shackle leveling kit,disellite a/c cold mod.,back up camera,Pillar isspro guages pyro,tranny,boost,OBA, DP Tuner(80E no codes,no start,drive thru),foil delete,CCV mod,JW valve body,wicked wheel,08 aluminum rear diff cover coming soon and then who knows but something!!!
  #2 (permalink)
Old 11-08-2009, 09:14 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
I don't know whats going on, but the factory diagrams do not show your truck having foglamps. I looked through everything, and even looked up the headlight switch diagram. They show the foglamp part of the headlight switch, but say "no connection" for your truck. Now if I look up a 2000 f150, they have a whole separate section in the diagrams showing the foglamp circuits.
Possibly these foglamps were added and that's why you cannot find the relay and related components?
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-08-2009, 09:29 PM
rtazz17's Avatar
2002 Ford F-350
No these are oem , listed on sales sticker. They are are built into the headlight switch, you pull the headlight switch out and they go on...
__________________
  #4 (permalink)
Old 11-09-2009, 01:06 AM
Franklin2's Avatar
I must be going crazy, I thought you had a 2000 f350. Anyway, they did have them in 2002.
The fuse is #43, 10 amp, in the underdash fuse box. The relay is located in the same fuse box under the dash.
__________________
Dave F
  #5 (permalink)
Old 11-09-2009, 07:00 AM
rtazz17's Avatar
2002 Ford F-350
I got the number 43, do you know which relay number?If not ill just switch each out. Funny though on my booklet not of the relays are labled for fogs
__________________
  #6 (permalink)
Old 11-09-2009, 10:26 AM
Franklin2's Avatar
AutoZone.com Repair Guide Image))
The links above are hopefully your fuse box. I keep looking and looking for the foglamp relay, and can't find it, and they do not list it as a replacement part. This means only one thing. They have built it into the fuse box, and it's not replaceable. We ran into this with the trailer tow running lights relay. Several people have had that go bad, and we found out the Ford engineers had a "better idea" and built it into the fuse box, and you have to replace the whole fuse box to fix it. Some people instead had added their own relay, bypassing the bad one in the fuse box.
A tan/orange wire leaves the fuse box to feed the foglamps.
__________________
Dave F
  #7 (permalink)
Old 11-09-2009, 10:49 AM
marktaylor marktaylor is offline
marktaylor is starting off with a positive reputation.
If fog light is not working it is needed to be replaced...light is very essential for any vehicle so its better go to the dealor and ask him to replace the lights
  #8 (permalink)
Old 11-09-2009, 10:52 AM
rtazz17's Avatar
2002 Ford F-350
Funny you say that. Thats what I was gonna do. Get some wire a relay and toggle. Atleast Ill be able to turn them on and off when I want to , not just eith headlights. Thanks for help. Ill try to rep ya
__________________
  #9 (permalink)
Old 11-09-2009, 10:53 AM
rtazz17's Avatar
2002 Ford F-350
Quote:
Yea, and pay through the butt.....
__________________
Tags
07 , 2004 , 2008 , f150 , f250 , f350 , fog , foglights , fuse , fusebox , lamps , light , lights , stopped , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
