Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-08-2009, 03:19 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
Test run
Well, I got the ol' girl out for a run the other day with the video camera and the GPS for verification. I posted 2 vids. Here's the link.
Let me know if it works. Redone1, I guess I didn't quite make my calculated target, but I'll keep trying. The speedo was showing 160 kph when I hit 190 (on the GPS)
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, SC 1705, Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 17* HPOP, 37/12.50/16.5's and some more stuff
  #2 (permalink)
Old 11-08-2009, 05:32 PM
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
Nice run! Must be nice having the room to let her go I imagine there are lots of nice straight stretches to hammer down in Manitoba here in Ontario there are too many hills and dips for the cops to hide at least you can see them coming LOL
__________________
96 PSD 4x4 cab 1/2 automatic
Intake mod,3" down pipe,no cat,muffler, 203 stat,ccv mod Firestone air rite suspension
EBPV delete
  #3 (permalink)
Old 11-08-2009, 05:41 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
So how many MPH is 190KPH?
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #4 (permalink)
Old 11-08-2009, 06:26 PM
Quote:
118mph give or take
__________________
EBPV delete
  #5 (permalink)
Old 11-08-2009, 06:27 PM
95_Dually's Avatar
1995 Ford F-350
That is pretty fast for a truck. Good job.
__________________
Sam
  #6 (permalink)
Old 11-08-2009, 06:30 PM
Rice Rocket Eater
That would be 118mph. 160 kph (what the speedo was reading) is 100mph. I had a pretty decent side wind that day too. Maybe I'll try again on a calm day and see if it changes at all. I only hit 3000rpm on that run. I need more oomph........ I wonder if taking the cap off the truck might help a bit too. Notes for next time.
Waljon, there are some pretty good places to wind her up around here. Not near as flat as around Portage or Winnipeg, but good enough for my needs. I was pulling 28-29 lbs of boost too. And NO CODES!!!! I think I'll wait until I get the intercooler in for the next try though. My egt's were in the 1500 range!!!
__________________
Fullcrew7.3
Dave
  #7 (permalink)
Old 11-08-2009, 06:35 PM
Rice Rocket Eater
Good on ya Waljon, you beat me to it!
__________________
Fullcrew7.3
Dave
  #8 (permalink)
Old 11-08-2009, 10:40 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
That's pretty high egt's temp but I guess if just a short blast its OK.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #9 (permalink)
Old 11-09-2009, 06:38 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
Looking good!
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #10 (permalink)
Old 11-09-2009, 08:07 AM
Rice Rocket Eater
Glenn, you're right on the ball there. That's way above where I'd like to be, but IC's not in yet. It was only up there for 30-40 seconds.
__________________
Fullcrew7.3
Dave
  #11 (permalink)
Old 11-09-2009, 08:20 AM
redone1 redone1 is offline
redone1 is starting off with a positive reputation.
That is moving pretty good for our trucks, on gravel!
Wouldn't taking the cab off create more wind resistance? I always thought a shell would aid in aerodynamic air flow. Maybe I'm wrong. the shell would deff. catch more crosswinds though.
__________________
1997 F-350, 4X4, Standard Cab, Long Bed, 4.10's
DIY 6637, 3" DP, 4" straight exhaust, True-Cool Tranny Cooler, RDS Stage 2's, PHP Chip, Guages: Exhaust-Tranny-Turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
