1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 f350 no brake lights, please help?????
Old 11-08-2009, 01:15 PM
rigoberto's Avatar
rigoberto
rigoberto is offline
i checked all fuses and they're all fine,
can you guys help with the location of the brake fuse and brake relay if any,
i notice two days ago that the right side turned on very weak and latter it was fine i attache a trailer i just bought, i went around the block to test the new trailer brakes i just installed and when i came back i had no brake lights track or trailer, but i still have turn signals and emergency lights, I checked the brake pedal switch and i found power coming out when i depress the pedal but nothing goes to the brake lights
thanks in advance you guys are so kind just by taking your time to read other people's problems.
Old 11-09-2009, 12:24 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thread moved to the Superduty forum.
Old 11-09-2009, 01:14 PM
Surge08's Avatar
Surge08
Surge08 is offline
Did you have the recall done on the cruise control deactivation switch? if it has shorted out it will cause you to have no brake lights.
Old 11-09-2009, 03:35 PM
DetailerDave's Avatar
DetailerDave
DetailerDave is offline
I had the same issue a couple of weeks ago. The brake lights were out, but the third light on the cab was working. Turn signals worked fine, but the hazards were erratic. I could not locate a fuse at all, nor does the factory service manual indicate a location. I removed the turn signal switch from the column, and ran the point to point circuit test on it, but found nothing wrong. I put it back in, plugged the harness back in, then everything worked again normally, and has ever since.
Old 11-10-2009, 01:49 PM
SBastow's Avatar
SBastow
SBastow is offline
Had my brake light switch replaced. Problem solved
Biggziff
10-21-2020 09:53 AM
shargue
Electrical Systems/Wiring
08-13-2017 07:38 PM
Baicolt
04-22-2015 04:18 PM
wagontrader
02-14-2011 02:24 PM
southbound35west
11-30-2009 08:36 PM
Quick Reply: 99 f350 no brake lights, please help?????
