01 f150 4x4 actuator replacement tips - Ford Truck Enthusiasts Forums
Old 11-08-2009, 12:04 PM
BATTLIN_BLAZES's Avatar
BATTLIN_BLAZES BATTLIN_BLAZES is offline
BATTLIN_BLAZES is starting off with a positive reputation.
I've had issues with the actuator on the front axle for a couple years had to oftenly climb under and hit it with penetrating oil to get it to engage short term fix. It now won't engage I have looked for vaccum issues and it looks ok. I started to pull the actuator out and I'm stuck. does the shift linkage to the front axle need to come off or will the shaft slide by it while its on. also any tips on getting the whole thing broke free from the housing? I was thinking about cutting it off flush with a sawzall and tapping the rest out? it doesn't sem to want to budge. any help appreciated. thanks
the retainer clip is off it just wont budge from the hole!!
Old 11-08-2009, 12:07 PM
it does go through all the motions, all the clicks, goes into low range, actuator is attempting to move but not far enough to engage pretty sure it is the culprit. any removal tips? thanks again
Old 12-31-2009, 05:31 PM
carbon carbon is offline
carbon is starting off with a positive reputation.
Also looking for removal tips. There are two clips that need to be removed. I got the actuator half way out and can not finish removal or push it back into place. Really need help here. Also which way is engaged? (actuator shaft fully extended or compressed)?
Old 01-04-2010, 10:11 PM
jennkent5454 jennkent5454 is offline
jennkent5454 is starting off with a positive reputation.
I just replaced mine today, it wasnt super easy but wasnt super hard either. for it to come out the large e-clip needs to be removed, the smaller e-clip that is under the dust boot will fit through the hole. the little arm that sits into the shaft notch of the actuator needs to be out and away from the actuator shaft., I sprayed mine with WD40 and tapped it out with a screw driver and hammer, it is a very tight space to work in but I did get it out in about 30-45 min just trying to find something to tap it with. I have a repair PDF file I can send you if email me.
my email is my user name @ yahoo.
Old 01-04-2010, 10:17 PM
Emailed. Thank you.
Old 02-15-2014, 10:07 AM
Fordgrl83 Fordgrl83 is offline
Fordgrl83 is starting off with a positive reputation.
Mine had welded itself to the axle. My axle bracket snapped off. Now I gotta go find a new one. Junk yard scavenger hunt today -_-
Old 11-22-2014, 05:53 PM
Troy.cracroft Troy.cracroft is offline
Troy.cracroft is starting off with a positive reputation.
same problem
Hey I'm having this same problem could anyone help me get my hands on that PDF? Or how to remove and install
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
2003 F150 - water in 4WD vacuum actuator reidway 1997 - 2003 F150 3 02-15-2015 04:21 PM
Expy CV swap/Damaged 4x4 Actuator Shiro Elex 1997 - 2003 F150 0 07-07-2014 11:22 PM
06 F150 STX 4WD actuation issues mikecyr 2004 - 2008 F150 4 12-07-2013 07:25 PM
2008 F350 front hubs won't auto engage 4x4 xpl0sive 1999 to 2016 Super Duty 12 10-26-2012 10:43 PM
Tags
04, 1997, 1999, 2000, 2001, 2003, 2005, 4x4, actuator, engage, f150, ford, replace, vacum, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
