06 f250 w/5.4 no throttle just idle. Help
Old 11-08-2009, 10:00 AM
Leew222's Avatar
Leew222
Leew222 is offline
06 f250 w/5.4 loses throttle and will just idle until restart. Giving P2112 & P2104 codes. Please send any info. Thanks Lee
Old 11-08-2009, 06:53 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
Hey Lee!
Keep using the forums as you are you will get good help. It's fixable, but will take a little time to nail down what the problem is with the TBS sensor and how far you need to go.
Old 11-09-2009, 08:38 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Welcome to FTE
Old 11-09-2009, 12:14 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like the throttle body is stuck closed and the PCM has gone into forced idle.
Look here, page 86 and 96 for P2112, and page 93 for P2104: http://www.motorcraftservice.com/vdi...f/OBDSM608.pdf
Throttle plate is stuck closed, and PCM goes into limp mode. Either the throttle plate is really stuck closed, the actuator (servo/motor) the moves the throttle plate is bad, or the PCM can't move it because the PCM output is bad.
Most likely, the throttle plate is stuck.
Most likely, you need a new throttle body.
Old 11-09-2009, 01:18 PM
Leew222's Avatar
Leew222
Leew222 is offline
Thanks for the info. Will let you know how I made out. The throttle body is most likely a Ford Dealer only part.
Old 11-09-2009, 02:44 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I don't know the actual safety concerns involve, but if it were me, I'd check the throttle body just to be sure it moved easily. If it does, and you still get the "stuck" code, I'd wonder if the actuator is bad or something else was going on.
Of course, the actuator is not available separate from the throttle body I believe.
Old 11-09-2009, 03:17 PM
Leew222's Avatar
Leew222
Leew222 is offline
5.4 throttle body
Will try to clean it and see if it's binding first. Thanks again..
3/4tonfun
New Member Introductions
09-28-2009 10:32 AM
shaker429
04-13-2009 04:52 PM
Jason Bullard
05-31-2008 03:35 PM
Quick Reply: 06 f250 w/5.4 no throttle just idle. Help
