Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-08-2009, 03:04 AM
FordTruckChuck FordTruckChuck is offline
FordTruckChuck is starting off with a positive reputation.
Question Replaced Raditor now Runs Hot
Would anyone have any idea why my truck would run 15-20 degrees F warmer after I replaced the radiator?
The original 1 row radiator started leaking so I replaced it with a 2 row from AutoZone. I also replaced the original thermostat & O-Ring with new Motorcraft ones. I removed the drain plug on the driver's side of the block & flushed the system as thoughly as possible with a garden hose. With the old radiator installed, I filled the system with tap water & ran the engine thru a couple of warm up/cool down cycles to further flush the system including the heater core. I also removed the degas bottle & cleaned out all the build up from inside of it. Installed new radiator & filled with Prestone & distilled water. Reinstalled fan shroud,ect.
Went for a drive on the interstate & my scanguage II is indicating 204 degrees F. I've never seen it that high before. It's always stayed around 188. I'm getting 160 out of the heater vents. I've since reinstalled the original thermostat & replaced the original radiator cap, since it pressure tested alittle weak, with one from AutoZone & have seen no difference. I've had the dealership perform a few coolant flushes over the years including during 2 heater core replacements.
My truck is a '98 F150 XLT SuperCab LongBed 4WD 5.4L E4OD A/T A/C 6250 GVWR H/D Electical & Cooling Systems w/ only 70,2xx miles on it. I'm the proud original owner.
Please help!
  #2 (permalink)
Old 11-08-2009, 07:50 AM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Hate to say it,but the term "Autozone" has always worried me in the past.
Autozone is good for Batteries,oil and filters...nothing else.
Cant tell you how many New and reman parts ive had to take back over the years due to poor workmanship.
If I had my guess there are some restricted cooling veins in the radiator..It sounds like you have covered everything else except the Water Pump....Welcome to the forum!
__________________
Air Transport Radar Tech
  #3 (permalink)
Old 11-08-2009, 09:44 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
2002 Dodge Ram 1500
My Garage
bigdaddyII has a good reputation on FTE. bigdaddyII has a good reputation on FTE.
Did you "burp" any air that may be in the system out? Park the truck with front end higher than the back if possible. Remove the radiator cap and run truck up to operating temp with heater on high. When air burps out, coolant level should go down. Refill to correct level and shut truck down. You may have to do this once or twice again.
  #4 (permalink)
Old 11-08-2009, 11:02 AM
Thank you for the 'Welcome' n5926g.
There was air in the system at first but it seemed to come out after I revved the engine up.
Today I'm planning on going for a drive with no thermo in it. Then putting in a 170 degree thermo. Hopefully that will make a difference.
  #5 (permalink)
Old 11-08-2009, 07:21 PM
bigdaddyII's Avatar
2002 Dodge Ram 1500
My Garage
Let us know how it turns out.
  #6 (permalink)
Old 11-08-2009, 07:30 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of
I do not recommend the 170 stat. Jack the front of the truck up and run it until all the air is out to of the system. Be sure to do this with the heater on high.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #7 (permalink)
Old 11-08-2009, 08:36 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all shorebird is a name known to all
Stick to a stock temperature thermostat. Raise the truck front on a set of ramps and bleed the cooling system.
__________________
2001 E-350SD V10 Triton 3.73LS; '05 & '07 Taurus SEL's;
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb
Unique Collision Center Towing & Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #8 (permalink)
Old 11-08-2009, 11:56 PM
I went for a drive on the interstate w/o a thermo installed today thinking that would remove any air still in the system. Put the front end up on ramps when I got back & let it run for awhile. Then, I shut it down for a little while & started it again still on the ramps. The coolant level never changed during all this. I installed the 170 degree thermo,ran it for awhile & headed back out on the interstate. Temp stayed between 175-180 which I feel alot better about than 204 in 50 degree weather.
Why would it matter if the heater was on high or not? Isn't the same amount of coolant always circulating thru the heater core regardless of the setting selected since there isn't a cut-off valve?
During all this I noticed ATF leaking from the lower transmission cooler line connector at the radiator. I disconnected it & was able to tighten the adapter a very small amount. Then reconnected the cooler line & tightened the fitting as much as possible. But it still leaks. Of course it has to be the lower one which is very difficult to get a good look at. Tomorrow I'm planning on pulling the L/F wheel off & maybe even the plastic inner fender splash shield to try to figure out why it's leaking.
Would anyone have any advise on this new problem?
  #9 (permalink)
Old 11-09-2009, 08:34 PM
1998 Ford F-250
You might be able to use plumbers tape on the fitting to stop the ATF leak.
Watch your gas mileage with the 170 stat. The motor was designed for the higher temps and the computer is going to think the motor is cold with the lower stat.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #10 (permalink)
Old 11-09-2009, 09:17 PM
n5926g's Avatar
If you have a leak,and the lines are tightened properly,the radiator is a POS,,,Take it back to autozone,and get another one,or get a refund,and find a quality one elsewhere.I truly suspect it will solve all your problems.Seriously...Ive seen way too much of this from these guys
__________________
  #11 (permalink)
Old 11-09-2009, 10:53 PM
ole_smokey_88's Avatar
ole_smokey_88 ole_smokey_88 is offline
2002 Ford F-150
My Garage
ole_smokey_88 is starting off with a positive reputation.
Oreillys
Try oreillys they carry transpro which is a good brand IMHO i've got one on my 88 ford pickup never had any problems with it
__________________
1988 F-150 5.8ltr aka "Ole Smokey"
1989 F-150 4.9ltr "For sale"
2002 F-150 5.4ltr aka "Newbi"
Tags
bottle , burp , cooling , degas , ford , hot , run , system , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
