Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 11-07-2009, 11:18 PM
myhomerehab myhomerehab is offline
Garage is empty, add now
myhomerehab is starting off with a positive reputation.
Oil Leak from Oil filter on 5.4L Ford HELP PLEASE
I am at a loss This truck has benn down for a while and i finally got the parts and money to deal withit and now this. While the truck was just sitting in my garage not being driven for a lil over a year I walked in one day and saw all the oil on the ground i follwed it back to the oil filter and just thought that the truck did have alot of rust under it and maybee the filters rubber seal went. so I replaced filter and oil with all new. I finally finished the truck and it started right up but when I looked under it I saw OIL POURING out of the filter to the ground coming from one spot on the drivers side of the top of the filter where it seals to the truck its not all the way around the filter just one spot and when the truck is running it is literally pouring out. I shut off the truck and inspected for damage there was no visible damage and filter was tight. I havent pulled filter off yet but I have NO idea what this could be. PLEASE HELP WITH ANY SUGGESTIONS THANK YOU IN ADVANCE.
  #2 (permalink)
Old 11-07-2009, 11:43 PM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
Are you sure that you got the old oil seal off of the block?
Last time that I had something like this happen was the one time I didn't double check to see that the old seal was off.
__________________
'12 F250 Superduty CC 4x4 6.7L PSD
  #3 (permalink)
Old 11-08-2009, 02:03 AM
bada$$f150's Avatar
bada$$f150 bada$$f150 is offline
1998 Ford F-150
bada$$f150 is starting off with a positive reputation.
sounds to me like the old seal is still on there too.
__________________
-1998 4.6L F-150 4x4 Off Road Extended Cab
-Performance: True Dual Straightpipe Exhaust, Short ram Cold Air Intake, ECU rewritten, Helix Throttle body Spacer
-Other Stuff:Kenwood touch screen DVD Head Unit, 3-12" Subs, 3 Amps, Pioneer Doors, Optima Red Top, Playstation 2, MAX-4 Camo 4x4 Stickers, 33" BFG Mud-Terrains, billet grille
  #4 (permalink)
Old 11-08-2009, 01:21 PM
mylandscaper mylandscaper is offline
mylandscaper is starting off with a positive reputation.
Ok so I checked an the old seal was gone there was some corrosion build up so I cleaned it and it was only in the spot where it was leaking from so I thought sweet problem solved. Nope it's still pouring out when I start the truck I am positive it is coming from top of filter where seal should seal I am at a loss I can't even comprehend how I mean the seal is making a clean seal i don't know how the oil can get around it to pour out. I don't know what to do.
  #5 (permalink)
Old 11-08-2009, 06:01 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Do you have the correct filer on the truck now? FL820S
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'01 CVPI
'97 F150 5.4L
'09 F150 5.4L
  #6 (permalink)
Old 11-08-2009, 09:49 PM
ls973800 ls973800 is offline
ls973800 is starting off with a positive reputation.
I'd check the "top" of the filter housing to make sure a crack didn't develop there. See if you can feel oil right above where the filter screws on, or look at it with a mirror.
  #7 (permalink)
Old 11-09-2009, 10:28 PM
ole_smokey_88's Avatar
ole_smokey_88 ole_smokey_88 is offline
2002 Ford F-150
My Garage
ole_smokey_88 is starting off with a positive reputation.
Dont get offended by this but you did oil the new seal up before installing it ?
__________________
1988 F-150 5.8ltr aka "Ole Smokey"
2002 F-150 5.4ltr aka "Newbi"
  #8 (permalink)
Old 11-10-2009, 12:47 AM
yes I did oil the new seal i can not figure it out How much does the housing that the oil filter screws on to roughly go for is it worth replaving to see if that works???
  #9 (permalink)
Old 11-10-2009, 09:59 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
You need to change the oil filter housing to block gasket.
JL
__________________
2005 F250 Crewcab 3V V10/Torqshift/4.10LS
2001 F150 Supercab 4.6L/4R70W/3.55
1997 Thunderbird LX 4.6L/4R70W 12.16@111.78
2010 Lincoln MKT Elite-3.5L EcoBoost/AWD 14.41@96.27
  #10 (permalink)
Old 11-10-2009, 01:17 PM
Quote:
JL
Explain what do u mean change to "block gasket" pleaser
  #11 (permalink)
Old 11-10-2009, 01:20 PM
2005 Ford F-250
Quote:
The oil filter threads onto the cast aluminum oil filter adapter which is bolted to the cast iron engine block. There is a gasket between the two pieces.
JL
__________________
Tags
02, 150, 1997, 1999, 54, adapter, change, f150, f250, filter, ford, housing, leak, oil, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
