Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 11:40 PM
bornreadyredneck's Avatar
bornreadyredneck bornreadyredneck is offline
bornreadyredneck is starting off with a positive reputation.
86 ford bronco
air idle controle pluged in makes truck high idle at 3000 rpms an ideas what makes that happen ?
  #2 (permalink)
Old 11-08-2009, 12:32 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is online now
1995 Ford F-150
My Garage
9.ford.5 is gaining momentum as a positive member of FTE.
idle air control is screwed?
what happens when the IAC is not plugged in?
__________________
PROJECT and DD---95 ford f150 4x4, 300 INLINE SIX!, 5speed, SAS, 4" lift, 35x13.50 ground hawgs (sooner or later)
PARKED---91 ford f150 lariat, 302 v8, auto, 2wd, rust
PARKED---92 ford f150 xl ext. cab short bed, dual tanks, 302 v8, auto, 2wd, LOUD!, very little rust!
  #3 (permalink)
Old 11-08-2009, 09:06 AM
idles down i changed the air ilde controle it is new
  #4 (permalink)
Old 11-08-2009, 04:33 PM
wolfsmurf's Avatar
wolfsmurf wolfsmurf is offline
wolfsmurf is starting off with a positive reputation.
check for vacuum leaks, that early efi plenums sometimes pop a gasket.easy fix if it is.
__________________
ever wonder what a certain word means?
Dodge= Drips Oil Drops Grease Everywhere
Chevy = Cant Handle Even Volkswagons Yet
  #5 (permalink)
Old 11-08-2009, 04:41 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE.
you might also want to try the 86 bronco forum for some advice.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #6 (permalink)
Old 11-08-2009, 10:45 PM
i replaced all the intake gaskets so i dont know
  #7 (permalink)
Old 11-08-2009, 10:58 PM
i was told it was the injectors because the motor is out of a 90 and my truck is a 86 they might be diffrent ohms what u think ?
  #8 (permalink)
Old 11-08-2009, 11:02 PM
quicklook2's Avatar
codes.
more info.
bronco forum.
that is what i think.
__________________
  #9 (permalink)
Old 11-08-2009, 11:06 PM
new to this site how i get to bronco forms ?
  #10 (permalink)
Old 11-09-2009, 03:48 PM
Ricache's Avatar
Ricache Ricache is offline
1989 Ford F-150
Ricache is starting off with a positive reputation.
Go to the top of your home FTE page (has the pic's of 3 type of F1X0 generation trucks).
Below it are some pull down menus.
Home is the left most, Forums is right next to it.
Click on the forums and you'll see the list.
Scroll down to the bronco's forum.
There's a ton of forums on this site.
Good luck.
The best part of "Witless Protection" with larry the cable guy was his bronco! I'd like one of those.
/Ricache
__________________
1989 4.9 I6 Lariat M5R2 98K stock w/70 Flowmaster, stock tires, chrome rims, busted A/C, back tank inoperable, Love-to-drive-it Daily Driver.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
