Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 11:37 PM
Relics Relics is offline
Relics is starting off with a positive reputation.
starter problem
I put a 1978 351w engine from a Ltd and a c-4 transmision from a 1976 Mercury Monarch. Everything is fine but the starter won't turn flywheel. Flywheel is engaged by starter and I can see it move; but it seems to be in some kind of bind. I have removed torque converter bolts and the driveshaft and the bellhousing bolts and I think I am going to try to move it back and see if the torque converter and all the splines are aligned. Any thoughts and help appreciated.
  #2 (permalink)
Old 11-07-2009, 11:52 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc is starting off with a positive reputation.
You may not have the torque converter set correctly into the pump, creating a bind at the flywheel. If it's in right, the torque converter will sit way back in the bellhousing, and you will need to pull it forward so the studs go through the flywheel holes when the trans is attached to the engine. Another thing to check is the converter drain plug. It needs to go into it's flywheel hole, too. It's an item commonly overlooked, and it can get mashed against the flywheel, creating problems, too. Lastly, be sure you have the correct tooth flywheel for your transmission.
__________________
Wayne
52 Mercury M-1
among other things
  #3 (permalink)
Old 11-08-2009, 07:47 PM
starter problem
I got it corrected. Flywheel and torque alignment. Thanks.
Tags
ford , starters , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
