Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 10:27 PM
tazf250's Avatar
tazf250 tazf250 is offline
tazf250 is starting off with a positive reputation.
add 3rd row seat???
i have a 94 full size bronco 4x4 and i want to add a 3rd row seat does anyone know what small suv or other vehicle would have a seat i could get out of a wrecking yard that would be able to be bolted in the rear cargo area of my bronco? im sure it has been done im just looking for someone that knows what will fit. thanks for any advise.
  #2 (permalink)
Old 11-09-2009, 03:52 PM
alxsnmr alxsnmr is online now
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
I didnt think there was that much room in that area of the truck for a third row. They would be wedged back there like the back seat in a Porche 911. Probably the best would be take some measurements and hit the wrecking yard. An old middle row passenger van seat may work, and if you are into real fabrication, an old school bus seat could be fitted in there easily.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #3 (permalink)
Old 11-09-2009, 04:07 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco is starting off with a positive reputation.
I think the two biggest issues would be:
A) No leg room. You'd almost have to sit cross legged. It's only like 3 feet from the back of the bench to the tailgate. If you got a seat in there, there's no dip in the floor (like in front of the bench) to put your feet. If you raised the seat up to give leg room, there'd be no head room.
B) You'd have to do quite a bit of work to add extra bracing to bolt the seat in to. It's mostly just sheet metal back there. If it isn't worked into the frame, that seat will rip right out in any accident. Definitely doable, but still.
I think A is going to be the biggest issue. You just won't have anywhere to put your legs at all. Your best bet may be to keep your eyes out for a Centurion. They're an aftermarket 4 door Bronco.
__________________
4bbl Holley 390 w/ Offenhauser DP intake. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #4 (permalink)
Old 11-09-2009, 04:14 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
I hear what the guys are saying but I am almost certain there is (or was...geez I've been here forever) someone who frequented this forum who had done exactly what you are talking about with a third row Explorer seat. I could be completely wrong but you might run a search. Who knows, my memory isn't what it used to be.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #5 (permalink)
Old 11-09-2009, 04:16 PM
USAF FordGuy's Avatar
USAF FordGuy USAF FordGuy is offline
USAF FordGuy is starting off with a positive reputation.
Ive always liked those Centurions
  #6 (permalink)
Old 11-09-2009, 07:27 PM
kenpobuck kenpobuck is offline
kenpobuck is starting off with a positive reputation.
I added two jump seats from an extended cab ranger in mine. I fabbed up plates to sandwich the rear floor behind the wheel wells on both sides. I also made plates to attach the seat belts to the wheel well. It made mine able to seat 7 (small seats but useable) and I can fold them up and lose almost no room in the back. When folded they are nearly flush with the wheel wells.
__________________
DON'T BUY IT ..FAB IT!!!!
88 Bronco XLT 6.9 IDI, C6, Dana60 rear, 50 front, 3.55 gears, 33x12.5x16.5's. built by me becuase I just had to!
Kentucky Chapter Member
  #7 (permalink)
Old 11-09-2009, 07:49 PM
Off topic I know, but kenpobuck... you have a 6.9 international in a bronco! (droooling)
  #8 (permalink)
Old 11-10-2009, 06:59 PM
Yes, I swapped in myself in the driveway. I bought an 86 f250 diesel 4x4 donor and swapped the whole drive train. It is a beast and gets better mileage than the gasser ever did (17-18 mixed) with a c6 for now.
__________________
  #9 (permalink)
Old 11-10-2009, 07:08 PM
That is beautiful, had a F250 with that motor, luved it
  #10 (permalink)
Old 11-14-2009, 08:35 PM
tazf250's Avatar
thanks for the info, i will do some more messuring and see what i can make work. oh and for leg room this is being done so kids can sit in back so that shouldnt be a big problem
  #11 (permalink)
Old 11-15-2009, 10:11 AM
Encho's Avatar
Encho Encho is offline
Encho is starting off with a positive reputation.
Just keep in mind easy removal of the added seat, so if you need the cargo space it can be prepared easily.
__________________
1993 Special Edition Bronco (EB equivalent)
5.0lt V8, E4OD Auto
Member of the International Chapter
  #12 (permalink)
Old 11-15-2009, 03:26 PM
tazf250's Avatar
i think kenpobuck has the right idea i would love more info though like what year did you get the seats from and what kind of fab did you need to do? any welding needed or just drilling and bolting? please more info would be greatly welcome.
  #13 (permalink)
Old 11-16-2009, 12:22 AM
Encho's Avatar
Oh, also, have you checked the laws where you live? you'll probably need to put seatbelts there also.
__________________
5.0lt V8, E4OD Auto
  #14 (permalink)
Old 11-17-2009, 12:44 AM
95FordTruck02 95FordTruck02 is offline
2002 Ford F-350
My Garage
95FordTruck02 is starting off with a positive reputation.
I really like the fold up seat idea for the sides, and that setup would be easily had from any compact extended cab at a junk yard. You would be ablet o prop up slightly for a little leg room, and position just right for head clearance. A bronco seating seven, thats a neat deal.
But... I hope this is all done right with proper supports for the seats and seatbelts. I always do mods like this with the "what ifs" in mind, especially if there are going to be kids back there...
Tags
1992 , 3rd , add , adding , bronco , explorer , ford , jump , row , seat , seating , seats , small , thirdrow , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
