Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 10:23 PM
mkdubs mkdubs is offline
mkdubs is starting off with a positive reputation.
brake booster DIY??
Anyone know of a DIY for doing the brake booster and master cylinder?
__________________
Brandon martinez
  #2 (permalink)
Old 11-08-2009, 12:36 AM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
By DIY, do you mean "do it yourself"? Sure. Ask away.. This is a simple procedure.
  #3 (permalink)
Old 11-08-2009, 10:25 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
If you are adding power brakes, or installing a different booster, it is not a simple procedure...at all! It's a royal PITA.
1973/79: There are TWENTY TWO different brake pedals, NINETEEN different P/B boosters and SEVEN different clutch pedals. I kid you not.
Whatever the booster is from, the pedals must match it.
These pedals have ID numbers stamped on them. If the number matches the pedal(s) you have, it's a simple installation.
If the numbers do not match, you have to use the pedals from whatever truck the booster came from.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #4 (permalink)
Old 11-08-2009, 10:59 AM
lasthighboy lasthighboy is offline
lasthighboy is starting off with a positive reputation.
i just pulled a booster and master cylinder from a 74 f250 4x2 auto with front disc brakes and bolted it into a 70 f250 4x2 4sp that previously was all manual drum brakes. only had to change one brake line because the nut was the wrong size going into the mc. an adapter probably would have worked too if i had one. four bolts to hold the booster to the firewall and one holding the push rod to the pedal on the inside. everything functions properly.
  #5 (permalink)
Old 11-08-2009, 12:48 PM
my brake booster went bad, so i ordered a new one but i dont actually know the procedure to install the new one such as bleeding the master cylinder or something that im over looking. the truck is a 79 F150 4x4 no Cruise control
__________________
Brandon martinez
  #6 (permalink)
Old 11-08-2009, 07:54 PM
if you are just replacing the stock booster it is very simple. seperate the master cylinder from booster. (2 nuts, do not kink lines) four bolts holding booster to firewall. (can remove bracket with booster (four bolts) and seperate on bench or leave brackets on firewall and just remove booster (4 nuts). remove bolt under dash through brake pedal. install in reverse order. no bleeding necessary. if replacing master cylinder also, remove lines from master cylinder. install new master cylinder onto booster. do not hook up lines. new master cylinder should come with adapters, bleeder hoses, and instructions on bench bleeding. after bench bleeding hook up lines and bleed brakes as normal.
  #7 (permalink)
Old 11-09-2009, 10:11 AM
thebaz67 thebaz67 is offline
thebaz67 is starting off with a positive reputation.
I am running into the same issue. I have a new booster and master cylinder.
However the booster rod needs to be adjusted, it is slightly longer than the old one. This rod is threaded what is the correct way to change its length?
thanks
Baz
  #8 (permalink)
Old 11-09-2009, 05:51 PM
mine will be in tomorrow, right now im fighting a brake bleeder that is rounded off, but do you guys bleed the master cylinder before attaching it to the brake booster?? I could have bought a complete unit but it was 40 bucks cheaper to buy them seperate so i did
__________________
Brandon martinez
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
