dual rear wheels - Ford Truck Enthusiasts Forums
dual rear wheels
Old 11-07-2009, 09:14 PM
projectdagger's Avatar
projectdagger projectdagger is offline
projectdagger is starting off with a positive reputation.
dual rear wheels
I have a 77 f-250 two wheel drive. Over in the local wreaking yard there is a 79 1-ton dually. I starting thinking about buying the rear duals off the one ton. My question, Do i need to make any modifications to the rear axle to bolt up the wheels? OR could i just bolt the wheels on?
Old 11-08-2009, 02:16 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink
I tried this many years ago and it won't work-I think you can swap the complete rear end though-or go and check out Arrowcraft - Dual Wheel Conversions for a quality adaptor kit to do it with your current rear.
Old 11-08-2009, 02:41 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Supercab View Post
I tried this many years ago and it won't work-I think you can swap the complete rear end though.
Dana 70: The rear end makes no difference whether it has SRW, or DRW.
What is different are the hubs, drums, lug studs and etc.
F250's were not available with DRW's.
There were no Styleside pickups available with DRW's until 1980, and then...F350's only.
Prior to 1980, all F350's with DRW's were sold as a Cab & Chassis, or with a factory installed flat or stake bed.
Old 11-08-2009, 02:46 PM
cjstang32 cjstang32 is offline
cjstang32 is starting off with a positive reputation.
Also, the frame on the F-350 is probably 34" wide while your frame (unless it's a high boy) is 37.5" wide. Chances are the inner duals would rub.
Old 11-08-2009, 03:05 PM
1967/77 F250 4WD's (High Boys) have rear frame rails that are 33 1/2" apart.
Some F350's thru 1979 also have these narrow frame rails, some have frame rails that are 37 1/2" apart.
All other 1973/79 F100/250's have rear frame rails 37 1/2" apart.
Old 11-08-2009, 05:00 PM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
I have a dual rear wheel adapter kit on my f250 4x4 crew that I am not going to use...I know it was an add on but it is available, pm me if anyone is interested in it.
Arrowcraft does not make the drw fenders for the dentsides any more. I sold a set to a guy in Colorado from my 77 crew cab, I just took the duallies off and put on aftermarket 10" wide rims.
Old 11-08-2009, 05:25 PM
1800joedaddy's Avatar
1800joedaddy 1800joedaddy is offline
1800joedaddy is starting off with a positive reputation.
Just got through doing my fronts, they're a direct bolt on. It was said earlier that there is no difference in the rear? Only about 4" inches a side. It's true the hubs and parts will interchange but the axle width is shorter in relation to the DRW. Just swap front hubs and the complete rear and save $ over the arrowcraft stuff which is not as strong and will cause problems if you load it heavy, say with a gooseneck.
I'm using these fenders.
My front hubs cost me about $50 and they take standard 1 or 3/4 ton bearings.
Pm me or check my build if you need help. Good Luck!
Old 11-08-2009, 10:49 PM
If i could, i would just buy the whole from the wrecking yard. But the owner will not sell it complete. My truck and the one ton dually is a 2 wheel drive. So if i buy the complete rear axle from the one ton. Would it bolt into my f-250?
Old 11-08-2009, 11:18 PM
Quote:
Measure the distance between the pads to be sure but I'm going to say yes.
Converting F250 to Dual Wheels??? Richard H. Brakes, Steering, Suspension, Tires, & Wheels 11 08-15-2016 10:43 AM
Towing and Dual Rear Wheels kb9nvh 1999 to 2016 Super Duty 10 04-22-2015 06:22 AM
dual wheels jon on the mon Brakes, Steering, Suspension, Tires, & Wheels 3 09-23-2014 01:54 AM
putting dual wheels on single rear wheel axle 1978fordf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 04-22-2008 09:17 PM
410 to 373 rear end conversion mediumfry 1999 to 2016 Super Duty 8 01-02-2003 04:27 PM
Tags
axle, back, conversion, dual, duel, fenders, ford, pickup, ranger, rear, truck, trucks, wheel, wheels, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
