Truck backfiring, won't run right.
On my way to work this morning the truck was running properly. I had to slow down for a turning car and while getting back up to speed it suddenly started sputtering and backfiring through the exhaust. It will idle but starts backfiring and sputtering when you give it gas. It's getting fuel but maybe too much? It's got an edelbrock 600cfm on it. The only way I got it back to my house was by playing with my points. I thought they could have possibly shifted causing a poor spark. I can now get the truck up to 40mph with minimal backfiring but after that it's a no-go.
When I get back home, what do I need to look at first?
I just fixed my 390 with the same problems check your filter for blockage, check your fuel pump make sure it runs fine, and if that doesn't fix it check your fuel lines everything make sure that there is no restriction. This probably is not the case with yours but someone hade used 1/8in copper tubing in place of my steel and in some spots rubber line severly restricting fuel flow there was enough to idle and fill the carb bowls, but as soon as you stepped on the gas there was not enough flow to keep up with the demand of the engine thus acting like it has run out of gas.
This is definitely not an issue of fuel getting to the carb. I'm going to go ahead and convert my system over to electronic distributor. Went and borrowed the stuff from my '76 F250. I have a feeling that the pin that holds the gear that connects to the camshaft that turns the distributor may have sheared. Like how I worded that? If it did shear, the gear could have turned ever so slightly.
Anybody know the correct part number for the Pertronix electronic conversion? I can't find the right thing for a '74 Ford F100 with 390.
The engine might even be a '69 or '70.
I found the crane cams which is magnetic,
Crane Cams 750-1700 - Crane XR-i Points-To-Electronic Ignition Conversion Kits - Overview - SummitRacing.com
And the Accel which is optical,
ACCEL 2020 - ACCEL Points Eliminator Conversion Kits - Overview - SummitRacing.com
What's the best to go with?
tkisling
17
12-22-2016 10:45 PM
SWD75
08-07-2016 07:43 AM
supermandn59
1983 - 2012 Ranger & B-Series
02-17-2011 07:38 AM
