Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 09:38 PM
mountaineer27's Avatar
mountaineer27 mountaineer27 is offline
mountaineer27 is gaining momentum as a positive member of FTE.
i can figure out my boost!
my truck is a 97 f250. its intercooled with a dpp chip. i just added a .84 turbo housing and 3 inch downpipe to my 4 inch turbo back stacks. also have the beans tymar intake. sounds wicked going down the road but my digital turbo gage is running neg 2 psi at idle and all it will read is 8 psi redlining the old girl. dont forget i have stage II sticks so i know i should be getting more boost. its sounds like a lot more boost buil maybe my gauge when out. i dont know why because it worked good with my 1.00 housing. could push 25 psi. any ideas?
__________________
1997 F250 XLT 7.3 PSD. AR .84 HOUSING , STAGE II STICKS, TYMAR INTAKE, 3" DP 4" BACK, DPP 6 POS CHIP (140 HP), GLOWSHIFT BLUE DIGITAL GAUGES, 10,000 LB WINCH, 5000 LB REAR FIRESTONE AIR BAGS.1987 Chevy K10 4x4 short bed stepside. cummins 5.9, 6" straight cut stacks, 12 superlift, shakel flip, 44 boggers, 16 bolt 1ton full floating axle's, 4 spd man trans, 513 gears locked all the way around. - JEFF
  #2 (permalink)
Old 11-07-2009, 10:01 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
I never heard of the .84 but when you hit 25psi did you have your IC in? I'm just thinking that you have a leak somewhere in your tubing. Just a guess. You have some great mods, I've been thinking about that D66, how do you like it over the stock one?
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #3 (permalink)
Old 11-07-2009, 10:07 PM
it takes care of the turbo surge ok but to me it seemed about the same performace of the ar 1.00 housing so i sold it. just forgot to take it of my sig lol. thanks for pointing that out. its been a bit since ive been on here. a lot of changes! but i dont think i have any leaks because it has a lotttttttttttt.... more power. plus thats the first thing i checked. maybe i blew out the boost sensor? i dont know what its rated at but i dont think it pushed over 30 psi into it. its been bafelling me for the past week now.
__________________
  #4 (permalink)
Old 11-08-2009, 01:56 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
Maybe the tube for the boost sensor got pinched or clogged?
.84 housing, wow! I heard of guys having overheating issues with the 1.0 housing on our trucks
what made you want to go with the .84 housing?
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #5 (permalink)
Old 11-08-2009, 12:30 PM
good call. i think ill replace it today and see if its that tube is clogged. i went with the .84 for more boost. im not worried about overheating as much because im intercooled and even with my 1.00 i never had a problem
__________________
  #6 (permalink)
Old 11-08-2009, 04:34 PM
well changed the tube and still not good. its a beautiful day so i thought ill play with the chip a bit. here you go
******** width="425" height="344">*********>
__________________
  #7 (permalink)
Old 11-08-2009, 06:38 PM
Talyn's Avatar
Talyn Talyn is online now
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Where did you install the sensor? in the spider or the map line?
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
  #8 (permalink)
Old 11-08-2009, 07:05 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
Fisher of Men
tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE.
Not much help on the boost other than you probably have a leak somewhere or the gauge got messed up. BUT IMO the .84 housing is way too small for stage 2's. I also believe the 1.0 is too small for stage 2's. I ran the 1.0 for a while with just AD's which are about 140 cc's and I noticed no change in performance going back to the stock housing but I did run cooler even with an intercooler.
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 260K
I will keep My Money, My Guns, My home and My Family. YOU KEEP YOUR CHANGE!!
  #9 (permalink)
Old 11-08-2009, 09:22 PM
you didnt notice faster spool up? now i didnt notice any difference between the 1.00 and the d66. but the .84 sounds like a 6.0 and u can tell the boost is there off the line. anyway i put my 1.00 housing back on and im pushing right numbers. glad i throught the head stud kit on!
__________________
  #10 (permalink)
Old 11-08-2009, 11:03 PM
Talyn's Avatar
1994 Ford F-250
you get correct boost numbers with the 1.0 housing?
__________________
  #11 (permalink)
Old 11-08-2009, 11:11 PM
well, i dont know if there correct or not but what i got before with it. with the .84 i only got it up to 12 psi today. with the 1.00 i pushed 31 psi out of the old girl.
__________________
  #12 (permalink)
Old 11-08-2009, 11:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
weird, i would confirm your digital gauge readings with a manual gauge. i think you will find your numbers are ALOT higher then what you think.
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
Tags
84 , housing , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
