I would think it would be easier to rebuild the engine you have now. The head gaskets can be done without removing the engine. It is a lot of work, but so is and engine swap. That being said, there is a sticky on the top page that walks you through pulling the engine from the front.
Yes, the '92 engine will be the same, you may have to swap manifolds, and some other stuff off your old engine, but the block and head is the same.
