Was wondering if anyone has torque specs on the bolts for the t-stat, I changed mine and all my hoses today but looking under the truck I have a drip, so I went to advance got a new housing and gasket. I need the factory book's on this truck, next on the list to buy.
I just changed all my cooling hoses because of age, no visible cracking. Just to let everyone know what I found with 12 year old hoses, a lot of wear. i found the hose that goes to the bottom of the rad to be the worse, lying on the frame and wore to the point it was almost through. It is 1/2", with a 90* where it goes to the radiator, can't get one molded, I used PART # GY12UBP from advance ( E-Z Coil by GOOD YEAR ) and yes the tee is re-useable. The hose with the 90* that goes to the head off the tee I found in the back of advance auto parts, Part # 80400CSI. I used the CAT EXTENDED LIFE COOLANT, $11.00 gal., good for 300,000 miles with no additives to add, they are in it. Off to the next project.
Hussler, thanks for the link for the manual. It looks pretty thorough.
Reps Sent.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <>< 95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v 2000 Ranger 4X4 No MODS, yet!
Click on 03 - Engine
Click on Section 03-01D Engine Diesel 7.3
Click on Removal and Installation
Click on Water Thermostat
Spec is 15 lb-ft
DUDE! That id great!
Have you got a link for other years so I can ?
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
