Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 07:13 PM
Stephen67's Avatar
Stephen67 Stephen67 is offline
1956 Ford F-600
Stephen67 is starting off with a positive reputation.
Master Cyclinder
My brakes don't really kick in till I get down to the last two inches, something I don't like. So today I opened up the master cyclinder, it looked pretty full but I filled it up all the way to the rim and let the excess run out when I put the bolt back on.
This style however is new to me and I don't know if it should be doing what it did. I pressed the brake pedal down, which I could feel working in the first inch, but then the oil shot out of the top of the nut, through some pin hole about 12" high (not around but through the very top, had to be there for a reason, my reaction was very comical). I pumped it a few times and eventaully it went back to where it was. I don't know if this is a safety mechinism to keep it from having too much, or if it's not suppose to do that normally, the brakes are a little better, but not as good as when the MC was completely full.
Again, these are new to me, and I don't know if this master cyclinder is specific to the '56 F-600 or anything. It suppose to do that? lol
__________________
Build it like you're the last person on earth.
Selene '67 Mustang
Abby '56 F-600
Those who dance are often thought as mad by those who can't hear the music.
  #2 (permalink)
Old 11-07-2009, 10:00 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has a good reputation on FTE. AXracer has a good reputation on FTE.
What year, type of MC are we discussing here? Sounds like you might be talking about the bleed nut used for bleeding the air out of the MC. Looks a bit like a grease fitting usually on the side of the MC. Try tightening the nut (a little more than snug, but not too tight, then fill the res. and pump the brakes. Does fluid still shoot out the fitting? Does the pedal get firm higher up when you pump it?
Or are you maybe talking about the air vent in the top of the MC cover? If it's coming out of the cover then you likely overfilled the MC, there should be a ~ 1/4" air space above the fluid when full, it is often marked with a full line. Some MC have a rubber bellows type membrane that goes on before the cover to seperate the fluid from the air above it, and it keeps fluid from coming out the vent. Be a bit careful splashing brake fluid around, it's a pretty strong solvent that will attack most paints it come in contact with in just a couple minutes.
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP racer, the "KRAZED KANARY"
2002 Celica GT 2003 GSL National Champion retired to daily driving duties
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
