I'll give the wheel a look to see if I can feel any play. I just had the entire front end apart last month. I replaced the ball joints, needle bearings, axle u-joints, inner axle oil seals, all dust seals, o-rings, ESOF hub service, etc. I packed the needle bearings and lubed everything up good. I'll check the brakes again too. I recently performed the caliper slide pin upgrade. I've always heard the front ends on these trucks have a reputation.
__________________
Jason
2000 F350 XLT PSD CC 6-sp SRW 4x4
6637
