Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 06:30 PM
Mark Mills Mark Mills is offline
Mark Mills is starting off with a positive reputation.
HELP: 1993 Ford f250 duel tank problem
Hi guys,
I had the pump replaced in the rear gas tank (both pumps were out, front and rear) by a real lame mechanic. I had to take it back three times before I said f it. The problem is that when I put fuel in the rear tank , as I drive it the gas goes to the front tank. Hence I manually siphon from the front tank back into the rear tank. Could this be the switch F/R tank? Any help would be greatly appreciated.
  #2 (permalink)
Old 11-07-2009, 06:37 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
You have a bad fuel module in the front tank.
As it is a 93 I would look close at the Fuel Pump Regulator (FPR) as they were bad from the factory that year. The bad FPR would blow the the non-running fuel pump check valve and cause what you are describing.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 11-07-2009, 06:38 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is starting off with a positive reputation.
Keep taking it back to the "real lame" mechanic until he fixes it right... and doesn't charge you anything for it. He did a job for you, and he didn't do it right- he should fix it.
__________________
"Official Project Stages: (1) Uncritical Acceptance. (2) Wild Enthusiasm (3) Dejected Disillusionment. (4) Total Confusion. (5) Search for the Guilty. (6) Punishment of the Innocent. (7) Promotion of the Non-participants."
-Unknown
  #4 (permalink)
Old 11-07-2009, 06:43 PM
subford's Avatar
It sounds like the he did the work OK on the rear tank the only problem is he was working on the wrong tank. I have heard of Doctors doing the same thing.
__________________
subford@gmail.com
  #5 (permalink)
Old 11-07-2009, 09:47 PM
Thanks for the help. Sorry about the repost (3) my computer is doing some crazy things.
  #6 (permalink)
Old 11-16-2009, 07:05 PM
Duel Fuel Tank Problem
Hi Bill,
Thanks for taking the time to help me out. Is it a big deal to replace the Fuel Pump Regulator in the front tank (cost/labor). I am trying to sell the truck so needless to say, do not want to put a lot of money into repairs. But of course would like for everything to work properly when showing it.
Thanks again for the help.
Mark
  #7 (permalink)
Old 11-17-2009, 07:03 AM
subford's Avatar
The Fuel Pump Regulator in mounted on the fuel rail on the engine.
The FDM (fuel module with pump) is inside the fuel tank.
__________________
subford@gmail.com
  #8 (permalink)
Old 11-17-2009, 08:21 AM
OceanCntyGuy08005 OceanCntyGuy08005 is offline
OceanCntyGuy08005 is starting off with a positive reputation.
I had the same problem on my 96 250, replaced both tanks, sending units an pumps
cleared the problem right up
  #9 (permalink)
Old 11-17-2009, 04:29 PM
Boss F150 Boss F150 is offline
Boss F150 is starting off with a positive reputation.
Quote:
Originally Posted by Mark Mills View Post
Hi Bill,
Mark
The regulator on the rail is easily replaced. There are 3 allen head bolts that holds the regulator to the lines. Pull off any lines and hoses, reverse the steps to install new one.
On my 5.8L F250 it took about 15-20 minutes in a dark parking lot. Great thing is that the bolts when tightened will press the fuel lines onto the regulator.
Tags
1993 , 93 , f250 , ford , forum , fuel , pictures , switch , tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
