Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 05:12 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
Got tires that are too big for my wheels
So now of course I need new wheels!
Anything wrong with wheels like these on ebay? I didn't know you could get a set of wheels for $100/each!
http://cgi.ebay.com/ebaymotors/16X10...item5ad4a17b2b
Opinions or other sources appreciated. I am looking for something simple, OE style (OE don't come more than 7 inches wide that I can see), spoked if possible. The ones I was finding were mostly drilled. I don't care for faux beadlocks, painted wheels or ornate wheels. I would prefer a hub cap that covered the lugs, but that doesn't look like a common option.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #2 (permalink)
Old 11-10-2009, 02:30 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
16X10 171 ION ALLOY WHEELS 8X170 8 LUG F250 350 99-04:eBay Motors (item 390114409259 end time Nov-11-09 05:41:29 PST)
They should fit. To facilitate the wider rim, the offset is 32mm (over 1 inch) more negative then OEM (-6mm) which may have an effect on front end wear (if you care).
I just bought a set of these and am very happy with the fit and quality:
Ultra Type 164 Polished
With most everything being lugcentric in the aftermarket world, the only caps I have found feed through the center bore and the lugs are exposed and chrome. Nature of the beast I guess.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #3 (permalink)
Old 11-12-2009, 12:19 AM
aldridgec's Avatar
I'm surprised there wasn't more discussion on this thread.
I'll have to pay attention to the specs, thanks for noticing that. I wouldn't be going with a 10 inch wide wheel anyway, only an 8. Here:
http://cgi.ebay.com/ebaymotors/16X8-...Q5fAccessories
I guess I'm mostly worried about quality. I'm sure I could spend several hundred $$$ per rim. I would assume mostly for the design. I'm not picky and if these cost this much and are strong enough, would certainly fit the budget. If factory wheels were wide enough, I would just get a set of them.
__________________
Chris
Current Vehicles:
  #4 (permalink)
Old 11-12-2009, 07:38 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ is gaining momentum as a positive member of FTE.
Hey Brian,let's see a pic of those on your truck.
__________________
Steve
2000 F-250 XLT 7.3L 4x4 LB
  #5 (permalink)
Old 11-12-2009, 07:46 AM
valves's Avatar
valves valves is offline
valves is starting off with a positive reputation.
This is where I got mine. They have free shipping.
Discount Tire, Custom Wheels, Truck & Car Rims | Discount Tire
__________________
04 F250 Harley Davison V10 4x4 CC SB SRW
  #6 (permalink)
Old 11-12-2009, 09:53 AM
aldridgec's Avatar
Quote:
__________________
Chris
Current Vehicles:
  #7 (permalink)
Old 11-12-2009, 10:37 PM
SGnAZ's Avatar
Those look good
__________________
Steve
  #8 (permalink)
Old 11-13-2009, 02:13 AM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
OK, so just to make sure I understand it correctly the hub mounting surface on this wheel is 5 mm closer to the inside (negative offset) from the centerline of the wheel which moves the wheel outward relative to the centerline of the truck (as opposed to a wheel with zero offset).
So how can it have a backspacing of 4.25" when it's a 8" wide wheel? Wouldn't that mean it has to have a positive offset? Am I missing soemthing incredibly obvious here?
I looked up offset on the Tire Rack Tech section, linked below, just to make sure that I had things straight in my mind but now I'm confused....
http://www.tirerack.com/wheels/tech/...jsp?techid=101
The reason I'm asking is that I found some 17X8 wheels for $50.00 each. They have the correct 8 on 170 mm bolt pattern, but they are +19 mm offset and 5.25" backspacing. It sounds like they won't fit right, that they will ride too far in against the front springs or something. I would like to get them if they fit properly but if anyone can help straighten me out on this I would appreciate it...
__________________
'03 F-350 XLT 6.0 PSD SRW SC SB FX4
Dieselsite coolant & tranny filters, Bright Box,
22" wipers, M-H FD RD Tranny covers, Fluidamper, leveling kit
TAG, Power Elbow, Blisteins, gages, MBRP 4" Turbo-back
XCal2 by SDT, HFCM drain, Centrimatic balancers
ESP luber, Oilguard bypass filter
  #9 (permalink)
Old 11-13-2009, 11:41 AM
aldridgec's Avatar
Hey Brian, what are the specs on your wheels? The link goes to a generic listing on tire rack and I couldn't look up specifics on the wheel. When I put in the truck type that wheel wasn't listed as an option.
I'm debating an 8 or 10 inch wheel now. It's only 3/4 inch difference tire width between your tires and mine, and your tires look good without the wheel being too wide. I would assume you have an 8 inch wheel. I'm just not sure if the tires will still look sucked in with only an 8 inch wheel on mine. 9 would probably be ideal, but I don't see many of them.
I also am getting conflicting info on the factory offset. I've seen lots of wheels that show to be factory replacements at -6. My book specs show it to be +10. Where did you find your info saying it was -6? I may end up taking a wheel off and measuring to be sure.
__________________
Chris
Current Vehicles:
  #10 (permalink)
Old 11-14-2009, 12:13 PM
Forresth Forresth is offline
Forresth is starting off with a positive reputation.
I didn't see a weight rating listed in the descriotion.
  #11 (permalink)
Old 11-14-2009, 05:13 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
IL chapter LDR
2002 Ford F-350
BobbyDiesel71 is gaining momentum as a positive member of FTE.
just curious what tires you were running/bought?
truck looks good!
I went from a stock Lariat 16x7 rim running 305 Nitto Terra Grapplers to a
315/70R17 BFG AT KO on a 17x10 ProComp 8023 Extreme Alloy rim
__________________
DP TUNED
swamps single shots
02 F-350 lariat srw,longbed 4x4
Transgo Tugger II, TRU-COOL 4739, AFE stage II intake, Bully Dog 5" turbo back exhaust
  #12 (permalink)
Old 11-16-2009, 01:47 PM
brian42's Avatar
The closest data I could find was that the OEM offset was -6.35mm (found it on-line somewhere). I can't remember where they actually measure for backspacing (lip, edge or tire mounting surface), but since I was not too concerned with rubbing the springs or compensating for a crazy offset with spacers, I just concentrated on the offset to match factory and maintain the design load bearing on the front end components.
With the 285/75-16 E rated BFG Mud-Terrain TA KM2 tires, I haven't rubbed at all, but it's close. I can't imagine going any wider without having some kind of rubbing issues at full lock. I off-road a lot so I wanted an agressive tire, but I didn't want to worry about rubbing all the time.
Here's the spec's for the wheels:
Load Capacity: 3400lbs
Backspacing: 4.25"
Weight: 20lbs
Offset: -6mm
Width: 8 inches
Diameter: 16 inches
Quote:
truck looks good!
Thanks for the props!
I bought the tires and wheels from Discount Tire. They called Ultra and there was a 45 day backorder for the wheels, but Tirerack had 16 in stock, so they bought them from Tirerack at my cost which was $120/wheel. The wheels came with chrome acorn lugs (32), chrome caps, a socket for the lugs and a Gorilla lug wrench.
I've only had them on for a week, but they look great and the tires are surprisingly quiet. At freeway speeds, it sounds more like wind (like riding a steel rollercoaster) than tire noise.
Wheels
http://www.ultrawheel.com/pdf/rims/164.pdf
Tires
BF Goodrich Mud Terrain T/A KM2 tires - Reviews, ratings and specs in the San Diego Area - Discount Tire/America's Tire
BFGoodrich Tires | Mud-Terrain T/AŽ KM2 | Tire Sizes & Specs
Tire Rack doesn't list the E rated 285/75-16 (You have to go to BFG's website for that). The tires are rated 3750lbs @ 80psi and have 19/32" of tread.
__________________
THE MOOSE
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
