Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 04:38 PM
airassaultinfantry1 airassaultinfantry1 is offline
airassaultinfantry1 is starting off with a positive reputation.
Gutting turbo pedstal to non ebv
Greetings,
I was wondering if anyone has done this . I have the tap, freeze plug and the brass plug . I'm doing my homework as not to be taken off gaurd as with the ic swap .(thanks for everyones input) I have downloaded instuctions . I bought a kit for the back of the turbo w/ 4" down pipe from that little funny guy who wastes all the trees for 4 to 5 pages in diesel power . I started on fri. but had noticed an exhaust @ the up pipe . I went today and got 2 new gaskets and it looks like that will be nothing short of a nitemare . Any suggestions ?
Thanks
John
  #2 (permalink)
Old 11-07-2009, 05:04 PM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
It's not too bad of a job. The studs holding the butterfly to the shaft were harder than I expected to get out, but everything else was very straight forward. You'll do fine.
About the up-pipes -- start soaking the bolts now with PB Blaster. The sooner & longer they soak, the better. And be careful with the bolts -- they are known to break.
__________________
  #3 (permalink)
Old 11-07-2009, 09:57 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Gutting the EBPV is easy, just remember to leave the EBP sensor unplugged when you put the turbo back on. The up-pipes are a bit of a pain, but can be done. Make sure to get it lined back up properly when you put it back together. Also use plenty of anti-seize on the new gaskets and the bolts in the Y collector in case you ever have to take it back apart.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 11-07-2009, 10:02 PM
Orezona's Avatar
Orezona Orezona is offline
Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE.
Turbo :: Gut and Plug video by MazdaMartinb4k - Photobucket
__________________
Tuned by POWER HUNGRY PERFORMANCE
  #5 (permalink)
Old 11-07-2009, 10:19 PM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is online now
Fire Rooster is starting off with a positive reputation.
I gutted mine May of 03. has been workin fine as a non-EBPV pedistal ever since. Follow the instructions. (if they are the ones from Heatstroked....that is actually my pedistal)
__________________
You from AZ? Checkout
www.azpsg.com/index.php?referrerid=4
2002 F250 CC,SB,4X4,Lariat...2003 X, limited
  #6 (permalink)
Old 11-07-2009, 10:24 PM
did you notice anything afterwards ?
  #7 (permalink)
Old 11-07-2009, 10:32 PM
JockD's Avatar
JockD JockD is offline
JockD is gaining momentum as a positive member of FTE.
Has anyone taken the EBPV controller out of the pedistal when they gutted the pediatal? I have a spare one without the control and wonder if I can plug a passage or two to make a "blank" pedistal.
__________________
Jock - 2001 F250 Reg. cab 4X4, 7.3L with CCK, auto, 270,000 mi.
  #8 (permalink)
Old 11-07-2009, 10:37 PM
Izzy351's Avatar
Getting Faster...
The "passages" are like an 1/8th inch. Maybe. Probably more like 1/16th. They are very tiny, so it's not worth messing with, IMHO. Just plug the hole the arm comes out and call it good...
__________________
  #9 (permalink)
Old 11-07-2009, 10:39 PM
Quote:
Gutted mine completely. tapped the hole where the actuator arm came out of the pedistal. Put a 1/8 NPT pipe plug in it. put the plate and sap ring back in the other side and put in the truck. No issues since doing it. pulled the pedistal last night actually to redo the orings. After 6.5 years I guess the pedistal orings anted to leak a little. But as for the gutting...Nope issue free
__________________
  #10 (permalink)
Old 11-07-2009, 11:25 PM
61 uni's Avatar
61 uni 61 uni is online now
61 uni is gaining momentum as a positive member of FTE.
Joe, you did say use a 1/4 npt tap didn't ya? I got the tap today and it looks awful big.
__________________
Brandon
2002 Crew Cab f350 DRW 7.3. Stancor GPR 6637 Filter Gutted pedestal
1978 f350 400 4speed
  #11 (permalink)
Old 11-07-2009, 11:28 PM
Izzy351's Avatar
Getting Faster...
Yes, 1/4" NPT. It will work. Have you tapped before? There are a few tricks to it.
__________________
  #12 (permalink)
Old 11-08-2009, 02:18 PM
JockD's Avatar
The reason that I asked about the passages is that my spare pedistal is missing the controller. I will either have to find another controller to plug that big hole, or plug off whatever passage feeds to it.
__________________
  #13 (permalink)
Old 11-08-2009, 02:41 PM
Izzy351's Avatar
Getting Faster...
When you say "missing the controller", you mean you pulled the actual solenoid out of the front of the pedestal? I never messed with mine, so I have no idea what it looks like in there.
__________________
  #14 (permalink)
Old 11-08-2009, 04:54 PM
JockD's Avatar
There is a big recess that the controller fits into that has oil passages in it. The controller moves a piston in and out to provide a connection between the passages. I was wondering which passage the oil pressure enters the pedistal, and which one is for the return oil. I looked in behind the snap ring plate and see passages there, too. I was wondering if I can plug one of those to stop the oil flow.
Does the oil pressure go through the actuator chamber first before it gets to the controller, or the other way around? If I plug the oil to the EBPV system, does that affect the lubricating oil to the turbo, or are they completely different systems?
__________________
  #15 (permalink)
Old 11-08-2009, 05:52 PM
Izzy351's Avatar
Getting Faster...
I can't answer any of that. The only passages I saw were the small ones I mentioned in the chamber where the piston is (behind the big plug held in with the snap ring).
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
