Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 04:14 PM
d-dawg36 d-dawg36 is offline
d-dawg36 is starting off with a positive reputation.
Question 1991 explorer tranny issues
I am fairly new to the forum, so if I'm posting this in the wrong area, please let me know. I have a 1991 for explorer automatic with a 4" body lift 32x11.5x15" tires. 223,000 miles.
I just had the engine replaced, now the tranny is acting up! all gears work fine for a few minutes until the tranny warms up, and then it doesn't work at all in any gear. I know the a4ld tans is a total piece of S*#t! Is there an alternative trans that will bolt up without modifications out there? Is it something simple causing the problem? Any suggestions would be appreciated.
  #2 (permalink)
Old 11-08-2009, 12:23 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
No there is no easy bolt up for the A4LD.
Check the vacuum line to the modulator valve.
__________________
97, 4Dr, Controltrac, X engine, 360k
  #3 (permalink)
Old 11-08-2009, 05:41 PM
1991 explorer tranny problems
Thank you for the advice. I will check that out first, let's hope its something that simple!
  #4 (permalink)
Old 11-09-2009, 01:00 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is online now
KhanTyranitar is starting off with a positive reputation.
The A4Ld was an ok transmission, maybe a bit weak in stock form. Its greatest weakness however was that it does not tolerate neglect. Fuild changes every 30,000 miles at most is needed to prevent friction material buildup. Seems to me you have an internal leak that becomes more pronounced when the fluid warms up. This may be exaggerated by worn band and clutches. The stock system also has a weak cooler.
The A4LD is pretty good when upgraded. It is much better than the alternatives, i.e. chevies automatics or worse yet, a chrysler. The manual trans was a better choice, though not common. There are some transmissions that with the right bellhousing, can be used, but you will need to change the driveline too, and if you have 4WD, you may have to use a different Tcase. The A4LD uses a computer controlled 3-OD shift, and also the TC lockup is computer controlled. If these do not engage, you will have a CEL because the computer expects to see the load of the solenoids.
I would rebuild you old A4LD. There are upgraded aftermarket parts you can use, and you can also buy pre-upgraded transmissions.
  #5 (permalink)
Old 11-10-2009, 09:30 PM
thanks you for the advice! I think I'm just gonna have the old one rebuilt, but ask for some upgraded materials. I will replace the old cooler with an upgraded larger one as well.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
