Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 02:13 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
fuel pump check valve???
Working on a 88 Ranger 2.9L 5-speed ext cab.
The fuel pressure drops off fairly fast when turned off and I'm pretty sure that the check valve is bad. My question is, which pump has the check valve? It is a single mid tank set-up and has a pump in the tank and on the frame.
Pressure is fine while running. about 30psi @ idle and 40psi with no vacuum on the regulator. The pressure drops off within a couple of minutes which causes it to have to crank over for a bit to rebuild pressure and start.
It looks like the frame pump is readily available while the in take pump is special order. I just need to know which one has a check valve. I'm thinking the in tank pump, but I hate to waste $100+ for the wrong pump. It's my father in-laws truck and is is very good shape other than this hard starting problem.
Thanks,
Jimmy
EDIT: Pressure drop rate
30 psi @ shut off
25 psi @ 1:05 min
20PSI @ 2:30 min
15psi @ 4:45 min
still dropping
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #2 (permalink)
Old 11-08-2009, 07:08 AM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
The check valve is in the pump on the frame.
If you are saying it drops to 15 psi in 4 hours and 45 minutes that should be OK.
It will to zero over night but the fuel lines should remain full of fuel so that the one second the pumps run when the key is first turn on should bring it back up to the ~32-40 psi to start the engine.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 11-08-2009, 11:47 AM
LxMan1's Avatar
4 min and 45 seconds!!! Takes at least 2 key cycles to get back up to pressure, then it acts like there is air in the rail for a minute when it starts.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 11-08-2009, 03:40 PM
LxMan1's Avatar
Well,
I just wasted $90 on an unneeded frame mounted pump. There is no signs of fuel in the regulator vacuum line, so the diaphragm is good.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 11-08-2009, 08:19 PM
subford's Avatar
I take it the check valve was good in the old frame mounted pump.
I take it you did not try to blow air back through the frame pump after you took it off.
So then either the Fuel Pressure Regulator is not seating or the injectors are leaking then.
__________________
subford@gmail.com
  #6 (permalink)
Old 11-09-2009, 03:42 PM
LxMan1's Avatar
I'm leaning towards the regulator myself. It seems a bit slow to react when you mash the throttle. It climbs, just slowly.
No, I should have checked the old pump, but took a gamble and lost.
It doesn't act like an injector because it doesn't puff rich on start-up and acts like there is air in the line when it first starts then smooths out after about 5 seconds. Never smells rich like the fuel is in a cylinder either.
I have access to a 90 4.0 truck. I'm going to check to see if the regulators are the same before shelling out another $75 for a new one.
I appreciate your help Bill!!
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 11-09-2009, 04:33 PM
subford's Avatar
When you take the Fuel Pressure Regulator off put about 40 PSI air pressure on the Fuel inlet tube and see if it leaks out the outlet tube and none out the vacuum tube (should not pass air until 45 psi).
If no leaks @ 40 psi I would say it is a good one.
__________________
subford@gmail.com
  #8 (permalink)
Old 11-10-2009, 04:13 PM
LxMan1's Avatar
Twas the regulator. It's weird because the pressure still drops off fairly fast, but with the new regulator, the rail stays full and it starts right up. It even fired right up this afternoon after sitting since yesterday evening.
4.0 was different, had to get a new one.
Thanks for the help!!!!
__________________
88 5.0 LX Mustang
63 F100 351W/C6
Tags
150 , 1991 , 50 , 95 , bad , check , determine , f150 , ford , fuel , pressure , problem , pump , signs , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
