The intake manifold does not seal pressurized oil so that leak would not be directly related to oil pressure. Sounds like you just didn't get the gasket to seal properly. On the ends of the gasket did you use cork or rubber end seals? I would leave those out and use silicon on the ends.
As far as the running condition. I had a similar issue with my truck. There is a short rubber fuel hose on top of the tank that connects to a steel fuel line. My rubber line developed a crack and would leak when the tank was full or if I was on a downward incline. It also made the truck run lean at times since it was sucking in air. Good luck.
__________________
1977 Ford F-150 4X4 460 4-speed (dark jade metallic) Produced June 22, 1977
1966 Ford Fairlane 289 2 door hard top (black)
