Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 12:17 PM
wpkeeper wpkeeper is offline
wpkeeper is starting off with a positive reputation.
van turbo etc
For clarification... the van turbo comes from the econoline diesels? ie, one from an ambulance would work? also, anyone know anything about the dual alternator that I've seen on the ambulances? Maybe this would help my ongoing battery problems in my 7.3!!!!
  #2 (permalink)
Old 11-07-2009, 12:23 PM
FYI, my buddy bought a 7.3 motor off the local ambulance company. It wont stay running and their mechanics as well as FORDs said they would have to dig into the block to figure it out. (Mind you this is all third party info.) They don't think its worth it and the manager wanted the ambulance either running or off his lot. SO, the mechanic sold my buddy the engine and towed the remaining body away.
This means I have access to the alternator and turbo, IF it's the van turbo that I see that everyone has. Same friend is going to take the injectors, mail em off and put in some big oiler injectors. He's checking today to ensure that he has forged rods.
  #3 (permalink)
Old 11-07-2009, 12:55 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
Yes, that will be a "Van" turbo, which is a 1.15 A/R Turbine housing. You aren't required to have larger sticks but at least stage ones will help minimize the lag along with caramic coating or a turbo blanket.
On the alternators, IIRC the dual set-up only helps if you are pulling more than your single can put out ie. you won't have more at idle.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #4 (permalink)
Old 11-07-2009, 01:01 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Some ambulances were on truck bodies, so make sure it is indeed from an E-series. If it is, then yes, it's a van turbo. You *will* need custom tuning at least, like Clay is saying. I ran mine with stock injectors, and it was okay, but definitely lagged a bit. It's a complete dog on stock tuning, so I wouldn't even consider it unless you planned on getting tuned. FWIW, I'm running hybrids with mine right now, and it's still a bit laggy for my taste. Might end up with a 38r after all.
__________________
  #5 (permalink)
Old 11-07-2009, 01:20 PM
good to know with the lag... I am going to get a DP tuner when taxes come in... I'm waiting already!!!!! No plans for injectors though. so maybe i'm not interested in the van turbo??? I drive my truck daily and do tow with it enough for it to matter. As for the alternator, I'm currently troubleshooting my continuing saga of dead batteries... changing em out almost yearly. I hate having a broken down truck, and can't have the wife broken down if shes driving it for some reason. yet every year it gets stuck somewhere with a damn battery problem.
  #6 (permalink)
Old 11-07-2009, 01:21 PM
*** the extra motor etc is off an E-series... van ambulance, not truck with box build up.
  #7 (permalink)
Old 11-07-2009, 01:28 PM
papadelogan's Avatar
papadelogan papadelogan is online now
of Brent's moral decline
papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE.
If you had a van turbo with a 1.0 exhaust housing you wouldn't have such noticeable lag, but still, it won't spool quite as fast as the stocker with a .84 housing.
__________________
Brendan
1999 F250 CC SB 4x4 7.3 PSD named "Nyx"
BTS VB;6637;A-pillar (pyro, boost, trans temp);XM radio;Alpine CDA-9831 w/RCA inputs;Leveling kit;Adrenaline HPOP;UnderCover tonneau cover;05 headlights
  #8 (permalink)
Old 11-07-2009, 01:34 PM
Izzy351's Avatar
Getting Faster...
It's definitely livable, and surely helps with EGTs when towing, I just want a little less smoke and a little more spooling. With the fuel I can now pour in there, it smokes like hell now until the turbo spools. It's really a bit of a PITA when trying to pass someone. Before the trans kicks down and the turbo spools, I smoke out whoever's behind me, and I'm not trying. I think there is some more I could do with tuning, so my mind isn't made up yet........
__________________
  #9 (permalink)
Old 11-07-2009, 01:54 PM
mueckster's Avatar
mueckster mueckster is offline
Redneck Wrencher
mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold
Quote:
I am having the situation with the 38R and 1.0 housing. I'll have the ceramic coated 1.15 on there when we have our PAA meeting at Rick's. You'll be able to see firsthand what the lag is like on the 38R combo. I'm sure we'll have plenty of notes to compare. My only real issue is with EGTs. I can live with the smoke, if I drive sensibly . I'm hoping the 6.0 IC/1.15 housing combo will keep my EGTs in check at WOT. I hate not being able to run at full potential.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6, AFE II w/ Pete's Cover, Garrett GTP38R w/ 1.15, 6.0 IC, Casserly SS 160cc 100% over, Stealth HPOP, Autometer Phantom gauges, DIY HD 4R100, 4" MBRP, Procomp lift pump, CCK, TruCool, billet 710 cap, Truetrac rear (soon)
PAA Member #62
  #10 (permalink)
Old 11-07-2009, 01:59 PM
Izzy351's Avatar
Getting Faster...
What are your EBP numbers with the 1.0 combo, Roland? I'm getting way up there with my setup -- not 2:1, but at 35psi, I'm getting to about 50psi EBP.
__________________
  #11 (permalink)
Old 11-07-2009, 02:44 PM
mueckster's Avatar
Redneck Wrencher
I haven't datalogged the EBP. I'll try to do a 'before and after' to see what differences I see. My EGTs peaked at 1400 in the 140 extreme tune and I hope the IC and housing will get the numbers down.
__________________
-Roland-
PAA Member #62
  #12 (permalink)
Old 11-07-2009, 02:47 PM
Izzy351's Avatar
Getting Faster...
1400 isn't too big of a deal. Just don't hold it there. I've hit over 1500 on my stock turbo.
__________________
  #13 (permalink)
Old 11-07-2009, 02:55 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 is gaining momentum as a positive member of FTE. Bigcat350 is gaining momentum as a positive member of FTE.
Roland I will bet you will like the new 1.15 coated housing, it helped my egt's I can stand on it now.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
