Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 11:58 AM
Tod1985F250's Avatar
Tod1985F250 Tod1985F250 is offline
Tod1985F250 is starting off with a positive reputation.
Starter Relay?
Sometimes it seems there is not enough juice to start the engine. At those times, I turn the key to on, open the hood, jumper between the positive battery terminal and the starter relay terminal, and the engine starts! Should I...
a. do nothing? (no thanks)
b. install a new battery?
c. install a new starter relay?
d. install a new ignition switch?
e. check the wiring between the ignition switch and the relay?
f. do something else? please explain
Thanks, Tod
  #2 (permalink)
Old 11-07-2009, 12:38 PM
87 XLT 87 XLT is online now
87 XLT is gaining momentum as a positive member of FTE.
There should be a wire with a rubber boot at the starter relay. Pull that off & jump 12 volts to that post.
Does it crank?
If it does you're not getting 12 volts from the ignition switch when you turn it to start.
Could be a bad ignition switch, bad neutral switch (slugomatic), bad clutch switch if it has a real trasmission, or a busted wire.
  #3 (permalink)
Old 11-07-2009, 01:00 PM
I jump 12 volts to the small terminal on the starter relay (the terminal that has the red/blue wire) and it cranks.
I have a 4-speed manual transmission.
Sometimes it cranks when I turn the key to start, sometimes it doesn't. Does that help to figure out what it could be?
  #4 (permalink)
Old 11-07-2009, 01:20 PM
My last starting problem was with my 87Ranger & it was the same as yours. Sometimes it would crank & sometimes not. Makes it kinda hard to find the problem
Starter relays are so cheap that I just went ahead and replaced it & that solved the problem.
Or you could connect your voltmeter to the red/blue wire & have someone turn the key a dozen times. Do you get 12 volts each time?
  #5 (permalink)
Old 11-07-2009, 02:27 PM
Thanks, I'll give that a try.
  #6 (permalink)
Old 11-07-2009, 11:12 PM
JimsRebel's Avatar
JimsRebel JimsRebel is online now
JimsRebel is starting off with a positive reputation.
Quote:
Leave the red/blue wire attached when checking voltage, the starter solenoid should click and you should get 12 volts and of course the starter should engage.
My point here is to test the red/blue wire under normal load/current draw, not just with it hanging in the wind.
When it "doesn't crank" with the key in start, do you hear the starter solenoid CLICK once... and then no starter/engine rotation????
Jim
__________________
1986 F150 XLT Lariat 4x4 300 C6, 9 inch 3:50, sway bars, DS2 w/ GM 4 pin and no computer; 90,000 miles, 2nd owner
  #7 (permalink)
Old 11-10-2009, 08:53 PM
hobbes's Avatar
hobbes hobbes is offline
hobbes is starting off with a positive reputation.
I just had sort of the same problem myself with my '86 302 efi, aod. I replaced the solenoid and it did not fix the problem, i ended up pulling the whole steering coloum (mine was cracked anyway) and replaceing it with one from a bone yard for 45 bucks and now i have no issues starting at all. It must have been an issue with the connection between the ignition switch and the wireing plug on the coloum.
  #8 (permalink)
Old 11-10-2009, 09:05 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
1956 Ford F-100
My Garage
dustybumpers is gaining momentum as a positive member of FTE.
could be that the clutch switch is starting to go bad. next time it wont start, stomp the clutch pedal to the floor a couple of times, and see if it will start then. my 1 truck has to be all the way to the floor before it will start. there is an adjustment for it, but I forget how.
__________________
Charlie
Join the Maryland Chapter click HERE
Tags
1986 , 1996 , 302 , 87 , bad , click , f150 , ford , ignition , problems , relay , solenoid , starter , system , truck , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
