Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 11:31 AM
Gavino4life Gavino4life is offline
Gavino4life is starting off with a positive reputation.
92' clutch work help!
I have a 92 f250 2 wheel drive, v8, 5 speed manual, and the other day i driving when from around the transmission area i heard like a screeching sound and it continued. Drove it home and later tried to start it and it wouldnt start. had a mechanic check it out, he said the rod from the pedal went bad or maybe it was that some piece that hooks up to the master cylinder of hydro fluid. he also said it was all linked back to that noise, and that i need a clutch kit. does all this sound right guys? what do you guys think before i invest money. thanks
  #2 (permalink)
Old 11-07-2009, 01:00 PM
PauL3861 PauL3861 is offline
PauL3861 is starting off with a positive reputation.
clutch trouble.
Hey bro. I was just getting ready to post my own similar question in here but I am about a month ahead of you with clutch headaches. I have an 89, 250, 5 speed.......I was having inconsistant clutch pedal travel for quite a while (sometimes full pedal travel and sometimes it would engage when the pedal was an inch off the floor) Then one day it just went out completely and the clutch pedal hit the floor and I had no clutch at all. Since then I have replaced the clutch master cylinder and tried to bleed it unsuccessfully. I have spent all my free time three weekends in a row trying different things and methods of bleeding this animal.. I finally decided that I had probably gotten a faulty replacement part and this morning I went to the part store and bought another one with the intention of returning the other one when I got the truck running. I am at the same point in the process. I cannot seem to get good fluid flow down at the slave cylinder????? I may need someone to help me bleed it down but I have been keeping a piece of tubing from the bleeder down to a bottle of hydraulic fluid just as I would if I was bleeding brakes. I also tried to just let it gravity bleed itself. So far I am clueless as to what is going on and I relish the thought of having my rig taken out on a flatbed to let someone else fix it. I cringe at the thought of any one wrenching on my own rig when I have the knowledge and time to do it myself.........As for your problem. Look under the dash and see it the push rod from the clutch master cylinder is still attached to the clutch pedal pin assembly. That is where you should start. There is a plastic insert that holds it on to the pedal pin. If the plastic wore out then you might need to reattach it some how. From there I would say that your noise could have been originating in the throwout bearing at the slave cylinder down in the tranny. If your clutch was not slipping and it was just making noise then you could possibly get out of this by having the clutch master cylinder replaced but that will put you to the same point as I am right now.. Pissed off, frustrated, and in need of someone to telll me what the F--K i'm doing. I am a shade tree mechanic but I will do just about anything including changing cranks and bearings and fulll motor rebuilds to swapping body parts and wiring harnesses......Good luck and IF ANY BODY THAT READS THIS CAN HELP ME, PLEASE CHIME IN
  #3 (permalink)
Old 11-07-2009, 06:09 PM
wolfsmurf's Avatar
wolfsmurf wolfsmurf is offline
wolfsmurf is starting off with a positive reputation.
Quote:
there is a switch on the clutch pedal that if it is bad or disconnected it would not let you start it. as for the sound if he couldnt get it started then there is no way he could tell you need a clutch kit.
__________________
ever wonder what a certain word means?
Dodge= Drips Oil Drops Grease Everywhere
Chevy = Cant Handle Even Volkswagons Yet
Tags
clutch , f150 , works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
