Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 11:26 AM
VORTMAX_99 VORTMAX_99 is offline
VORTMAX_99 is starting off with a positive reputation.
+2005 Hub Bearing
Has anyone replaced their 2005 or newer F250 Superduty Hub bearing?
I'm trying to find out if these have a separately serviced needle
bearings. The reason I ask is that I've got qute a bit of play at
the stub shaft/u joint connection (It's not the U joint itself)...
and it's popped the outer axle tube dust seal.
I'm able to find that up to 2004 there was a separately
serviced needle bearing...though I can't find a listing for the
2005 or newer models. Also can't find a listing for the 2005 or
newer hub/bearing assemblies...making me think they're different.
Any info appreciated,
Geo.
  #2 (permalink)
Old 11-08-2009, 11:14 AM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen is gaining momentum as a positive member of FTE.
yeah i just did the bearing that supports the stub shaft on the right wheel. 05 F350. the bearing had some play, the shaft seemed to have a lot of slop, new bearing made no difference in slop. the axle tube dust seal is best if installed in the garbage can just traps crap behind it the actual axle seal lasts just as long without it. if you install new bearings gently pry out the seal and put a couple extra shots of grease in, the sealed bearings have barely enough grease to coat the surfaces so the don't rust before you buy them. grease them now and never replace them again. if you haven't pulled it apart yet, i'd just leave it unless you have contamination in the vaccuum cavity. if you do pull it apart at some time and the stub bearings are ok then just grease them and save the 150 that ford charges for 2 bearings
__________________
2005 F350 Lariat crew 4x4
traded F350 XLT supercab 4x4 what a stinker
  #3 (permalink)
Old 11-09-2009, 07:13 PM
Hi again nitrogen and thanks again for the info.
(just saw your reply to my second query).
Based on your observations...I may just put the rotor/caliper/bracket
and hub back together. Haven't had any problems as of yet.
Thought I might end up with a gear oil leak...but it looks like the
inner seal (located in the differential housing) prevents oil from
migrating down the tube. I'll sleep on it tonight and make a decision
in the morning.
Thanks again for the info,
Geo.
  #4 (permalink)
Old 11-09-2009, 08:44 PM
craig2009 craig2009 is offline
craig2009 is starting off with a positive reputation.
Geo.
Hi all!
I've just visited this forum. Happy to get acquainted with you. Thanks.
________________
Free Anime Episodes
  #5 (permalink)
Old 11-09-2009, 09:29 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
in the morning.
Geo.
It's a lot of work replacing the axle tube outer dust seal. I would just leave it but you can grease the main hub bearing.
http://www.ford-trucks.com/forums/85...ml#post7593063
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
Tags
2005 , bearings , hub , superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
