Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 10:26 AM
g0dl355's Avatar
g0dl355 g0dl355 is offline
g0dl355 is starting off with a positive reputation.
Can I buy individual water pump parts?
I was taking my water pump off because I thought it was faulty.
Turns out the wheel that the pulley bolts to is cracked on one side, causing it to wobble off.
Can I buy just this part?
  #2 (permalink)
Old 11-07-2009, 10:52 AM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
???? a complete water pump can be as little as 12 dollars. I can t see any justification in trying to press a new shaft into one, or try to repair for the small amount of cash.
  #3 (permalink)
Old 11-07-2009, 11:12 AM
g0dl355's Avatar
Quote:
Yea I was going to head to pull a part anyway, just figured it'd be less hassle to take every accessory off to remove and install the pump.
Thanks
  #4 (permalink)
Old 11-07-2009, 03:50 PM
g0dl355's Avatar
Got me a new pump...well new to me haha.
If I take the back cover off the pump to clean it out, does it require a special gasket or just some rtv?
  #5 (permalink)
Old 11-07-2009, 04:00 PM
Fordworth's Avatar
Fordworth Fordworth is offline
Fordworth is starting off with a positive reputation.
I'm guessing you got it at the afore mentioned wrecking yard. How do you know its any good? It would really suck if you had to do the job twice because the replacement leaks from lots of mile or sitting dry for a long time. Anyway, silicone would be fine.
__________________
Why am I on the computer when I should be out making money?
1975 Highboy
390,C6, NP205, D60's
Custom suspension, 4 wheel discs, 38's
  #6 (permalink)
Old 11-07-2009, 04:29 PM
g0dl355's Avatar
Quote:
Well I will be adding a new gasket for the seal to the block, but I wanted to clear all the grime out of it.
Spins fine, lots of fluid poured out of just the water holes when I pulled it off.
  #7 (permalink)
Old 11-07-2009, 04:42 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
How much was the used one? As was said, a new one is so cheap, that buying anything else doesn't make sense.
  #8 (permalink)
Old 11-07-2009, 05:41 PM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
USArmyTaterness is starting off with a positive reputation.
A brand new LT warranty costs like $16
  #9 (permalink)
Old 11-07-2009, 05:52 PM
g0dl355's Avatar
Quote:
I couldn't find one for less than $50
I got this one for $8
  #10 (permalink)
Old 11-07-2009, 05:54 PM
really what shops do you go to though? I found three different ones at Oreilly from 16 to 40
  #11 (permalink)
Old 11-07-2009, 05:55 PM
Fordworth's Avatar
I would hope that you would use new gaskets but that has nothing to do with the condition of the pump itself. The fact that you need to clean grime out of it is not good. Grime wears on the bushing and seal. Just because it spins fine and didn't leak on a cold motor doesn't mean that the bushing isn't worn and it won't leak with some pressure behind it. I've got 13 years on a $29 pump that still works fine but I wouldn't be surprised if it took a dive tomorrow. You're trying to save a few bucks with a used pump of unknown age that won't last as long as a new one that doesn't cost much to begin with. You already indicated that you wanted to save the time and labor associated with changing the pump but you had to pull one off a junk truck, clean it out, and install it on your truck. Then you'll have to do it all over again waaay sooner than if you had bought a fresh one now. Where's the savings or the logic for that matter?
__________________
1975 Highboy
  #12 (permalink)
Old 11-07-2009, 05:59 PM
Water pumps are one of the things you dont buy at a junk yard unless you dropped the vehicle off yesterday.
  #13 (permalink)
Old 11-08-2009, 06:36 PM
Fordworth's Avatar
Quote:
Adn it was replaced the day before.
__________________
1975 Highboy
  #14 (permalink)
Old 11-08-2009, 06:57 PM
F250army45d F250army45d is offline
F250army45d is starting off with a positive reputation.
What motor you got we want to search for this part and compare prices? What you pay for the old pump?
__________________
Mikes Trucks
77 F250 4x4 Highboy FE410
78 F250 4x4 Flatbed 351M to 385
97 F150 4x4 Shortbed 4.2L V6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
