Truck runs fine when cold, but will die when you come to a stop after warming up. Will not restart until it cools off unless you hold gas pedal completely to the floor. Have already replaced the following: new computer, airflow sensor, fuel pressure regulator, throttle position sensor, distributor, plugs, plug wires, fuel filter, and injectors. Help...
That was good posting in the tech forum. I'm sure someone will be along to help you out with your problem. Look around the site and be sure to drop by your local chapter: Georgia Chapter - Ford Truck Enthusiasts Forums
