Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 08:22 AM
mds47588's Avatar
mds47588 mds47588 is offline
mds47588 is starting off with a positive reputation.
Has anyone adjusted the steering gear?
My truck has nary any freeplay after the balljoints and tie rod ends have been replaced, but there is still some considerable slop "on center" and the only thing left is the steerng gear. Of course I can get a new one, but I see where there's an adjustment (and a procedure in my Haynes manual), and before I go this route I'm curious if anyone else has done it and if so, have you been able to tell a difference.
__________________
'86 F-150 SB/300 CI/4 SP/OD (adding more weeky)
'02 Taurus SES (100K @ 100mph)
'06 Honda Rancher 4WD ES (max modded)
...all kept at a lil house way out in 'da stix...
  #2 (permalink)
Old 11-07-2009, 09:03 AM
roadrash63's Avatar
roadrash63 roadrash63 is offline
1985 Ford F-150
roadrash63 is starting off with a positive reputation.
yes i have...
but if you tighten it too much it over reacts and you need to back it off a turn...
i had better result replacing the rag joint!
__________________
Roadrash63
I'LL KEEP MY GOD,MY GUNS MY FREEDOM AND MY MONEY YOU KEEP "THE CHANGE"!!
saved since 83-shellback 87 usn
ford lover since79
1985 ford f150 4x4 302 fi t-19
2000 ford ranger 4x4 3.0 flex fuel
  #3 (permalink)
Old 11-07-2009, 09:06 AM
roadrash63's Avatar
1985 Ford F-150
hey which 4 sp od you got and how do you like it ?
__________________
Roadrash63
ford lover since79
  #4 (permalink)
Old 11-07-2009, 09:35 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
I did this as a teenager to my Mustang and ended up having a professional readjust it to
cure the problems caused by my screwing with it. Because of that experience - even
though I was a snot-nosed teenager at the time - I don't recommend messing with it.
  #5 (permalink)
Old 11-07-2009, 10:54 AM
rlester rlester is online now
rlester is starting off with a positive reputation.
I just did mine two weeks ago.
I had the same symptoms as you. Everything was tight, but there was slop in the middle. Quite noticeable on the highway.
I have also heard the warnings over the years but if you are conservative in your adjustments, and take a test drive and make appropriate adjustments, you will be ok.
On mine, I first tightened it a half turn. This was too much as the steering was a little tight (took a little more effort than usual) and would not re-center itself very well. I backed it off a little and in the end it has about a third of a turn from the original setting and its perfect. No more wandering on the highway.
Ryan.
  #6 (permalink)
Old 11-07-2009, 11:31 AM
okiepc1 okiepc1 is offline
okiepc1 is starting off with a positive reputation.
I have done this and it will help the problem, but before you start, mark the original position of the nut & the adjuster so you have a reference point, then you can always return to that setting & be sure to note the direction you turn
okiepc1
  #7 (permalink)
Old 11-07-2009, 03:12 PM
Ken Blythen Ken Blythen is offline
Ken Blythen is starting off with a positive reputation.
I did mine soon after I bought it - my kingpins & rod ends were good too, but it still wandered badly - I couldn't take my eyes off the road for more than a couple of seconds, it made driving hard work.
Adjusting the steering gear made a dramatic improvement, but following that procedure is important to avoid damage from over tightening.
__________________
1983 F250 XLT 2WD, 351W, AOD, 3.54 D60
1941 Ford 1 tonner - Deceased
1942 CCW-353 GMC 6x4
  #8 (permalink)
Old 11-07-2009, 06:00 PM
mds47588's Avatar
Thanx to all that replied. Did just this today and now it drives straight and true.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
