Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 08:01 AM
rogueinla's Avatar
rogueinla rogueinla is offline
rogueinla is starting off with a positive reputation.
Gauges not working
1970 F250, 390/AC, all the gauges quit working, I can't find a fuse for the cluster, cleaned the connector on the back of the cluster, didn't help. Is there a fuse somewhere for the gauges?
  #2 (permalink)
Old 11-08-2009, 12:31 AM
MotorDog's Avatar
MotorDog MotorDog is offline
MotorDog is starting off with a positive reputation.
Mounted on the firewall at about the position where the clutch pedal would swing up and into the firewall, there is a Fuse Panel with Five of the old Style round glass fuses that look like little tubes with metal ends. The third one down from the top is a No. AGA-2 Fuse which is for the Instrument Cluster Panel lamps. When this fuse is blown the instrument lights go out. This fuse does not protect the gauges. The power for the gauges comes from a little can that looks very similar to a 9 volt battery on the back of the instrument cluster and you will find the exact same plugs as for a 9 volt battery on the circuit board plastic on the 1970 F-100/F-350 trucks. Check for current with a multi-meter on these connectors. You could have a burned out Instrument Voltage regulator....... Good Luck!
  #3 (permalink)
Old 11-08-2009, 02:40 AM
rogueinla's Avatar
Thank you for the info, I'd checked the fuses, and saw that the I/P fuse just did the lights, didn't know about the other, I'll check it first thing in the morning. Thanks again
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
