Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-07-2009, 03:23 AM
Dads79's Avatar
Dads79 Dads79 is offline
Dads79 is starting off with a positive reputation.
Replacing glow plugs
I did a search first, but didn't really find an answer. My EX has 192.000 on the clock. I doesn't start on the cold mornings as well as it use to. Everything cycles well,and it always starts. And once started in the morning there are no other problems starting and running the rest of the day. I think it might be time for new glow plugs. I put a new set in my 96 last fall and it starts up great in the cold,even without using block heater. What is the best way to test them ? and how hard is it to change on the EX/Super duty-i.e . will the valve cover come of without removing the body? Thanks
__________________
Dads 79.
1979 F-150 4x4
00 Excursion LTD PSD 4x4 185K
96 F-250 SC PSD 4x4 245K
08 Roush 427R Mustang
  #2 (permalink)
Old 11-10-2009, 03:51 AM
officer131 officer131 is offline
officer131 is starting off with a positive reputation.
The valve caovers will come off without removing the body. I just replaced my glow plugs a month ago or so. I thought the passenger side was harded to remove than the drivers side.
check out some of my threads and you will see the process into checking them.
__________________
AL,
02 Ex. 7.3 diesel. 4" SS #409 MBRP exhaust. AFE stage 2 w/ pro guard air intake. DP Tuner F6: N/S, Stock, 80e, 120r, 80t, high idle. Autometer Cobalt gauges w/LED Boost, Pyro, Trans, And Fuel Pressure. Kenwood KVT-512 w/nav. bluetooth, & Ipod jacks.
http://www.roadsidehelpnetwork.info/...s/Page1344.htm
Tags
04 , 2002 , 2005 , 73 , changeing , changing , excursion , f250 , ford , glow , plug , plugs , replace , replacement , replacing , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
